Installing my chip?
Old Feb 8, 2006 | 10:46 AM
79f-250custom's Avatar
79f-250custom
Question Installing my chip?
Hey guys. when i bought my truck it came with a chip and i dont know where to plug it in at. it is a type of chip that you plug in and you just leave it.there is no buttons or anything on it. and i need to know where to plug it in at. if anybody could tell me or has any kind of pics that would help that would be great!
thanks for all and any help
Mitch
Old Feb 8, 2006 | 11:36 AM
Brians97F250Crew's Avatar
Brians97F250Crew
Here is one ....
http://www.hypertech-inc.com/get_ins...ion.php?iid=65
It's from hypertech but it'll give you the idea. There is another good one but I couldn't remember the link. I'm sure someone will post it up too.
Old Feb 8, 2006 | 05:28 PM
79f-250custom
Hey thanks man. that was a big help!
thanks alot
Mitch
Old Feb 9, 2006 | 12:17 AM
79f-250custom
OK guys. it looks like the chip will fit and all. but are you sure that is the right port for my superchip"s"? if i plug it in its not going to blow up or anything is it?
just making sure. i dont have the money if somthing messes up.
and also. what should i use to get that wax looking stuff off?
thanks.
Mitch
ohh and is there anything special i need to do before i let the baby loose? like turn the key on and off 10 times or just as simple as pluging it in and go?
Old Feb 9, 2006 | 11:59 AM
79f-250custom
OK. i put it in and nothing. i turn my key for the glow plugs to warm and the light wont come on. but all of the other 1's do? and when i turn the key i hear a clicking nose comming from the chip. why does it do this. ohh and hte truck wont start at all.
thanks
mitch
Old Feb 9, 2006 | 02:37 PM
Brians97F250Crew
Here ... this is super chips installation guide.....
Here
I've never installed a chip yet. But all I can say is make sure your connections are clean on the board and it's seated correctly.
Maybe someone else will chime in with more first hand insight.
Or give them a call .... their techs are very helpful every time I call ...
407-585-7000
Old Feb 9, 2006 | 03:01 PM
Max1775's Avatar
Max1775
Are you sure that the chip is for your truck? Each ECM is programmed with a code that must match the chip programming.
Max
Old Feb 9, 2006 | 09:26 PM
79f-250custom
Hey guys! thanks so much. both of those links really helped me out a great deal!!!!!!!!!!!!!!!!!! and yes i check it out and it is the proper chip for this truck max.
I dont think i had it good and clean. because i did have it in the right spot and all. so i will try in the morning.
thanks agin guys SO HELPFULL!
Mitch
Old Feb 9, 2006 | 09:36 PM
79f-250custom
Hey hey hey. i forgot to ask. what should i use to clean up the contact points???
thanks again guys!
Mitch
Old Feb 9, 2006 | 10:22 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Wipe the heavy gunk off with a little piece of scotchbrite pad with nail polish remover on it. Then make a little scrape in each of the boards contacts with a pocket knife.
If you are installing the chip with the PCM mounted in the truck and the batteries connected, make sure the key is not in the ignition.
Old Feb 9, 2006 | 11:54 PM
RubberDuck's Avatar
RubberDuck
I don't know if you pulled the computer out, but that's what Jody at DP tuner recomends. And doing so, I know why. That crap on the connectors is tough to get off. Jody said to use acetone and a scotchbrite pad. You can get acetone at any hardware store. I almost went too far, I could see the copper starting to show throught the silver pins. I would scrape a little with a pick and then scotchbrite with acetone. My chip had no problems at all. Hope that helps.
Old Feb 10, 2006 | 12:15 PM
79f-250custom
thanks a-lot guys!!!! ill go pull the computer out right now. and get some fingernail remover stuff on a tooth brush and start scrubbing away.i will also use some contact cleaner.
thanks for the input!
Mitch
Old Feb 10, 2006 | 06:20 PM
444dieselrod's Avatar
444dieselrod
What part of Wisconsin are you in. I am right by the border.
The no wait to start means that you dont have a good enough connection. have to reclean and try agian.
Diesel Rod
Old Feb 25, 2006 | 06:10 PM
79f-250custom
I have cleaned it 2 times. the first time i took the computer out and the 2nd time i just left it in there. could the chip be bad??? ahrg its so frustrating!!!!!!!! any help would be great!
Mitch
Old Feb 26, 2006 | 04:55 PM
444dieselrod
sounds like a bad chip then. I put mine all together, tested, then reinstalled PCM so that I didnt have to take it apart agin if I had a bad connection.
Diesel Rod
