Duraspark Stator
D = ILLUSTRATION SECTION 120 / PAGE 3 / Basic Part Number 12A112
Take a gander at the breakerless pic ref I posted above.
More importantly, how's she sound now?
I feel like a real idiot. I also have this problem posted on another site and have come to a conclusion that I should have caught quite a few post's ago. Bottom line is the dizzy is out 180*. Anyone who has posted trying to help me can feel free to let me have it. On the other post the guy worded his reply in a way that made me realize what I had done. I was sure that the dizzy could not be out 180* because I never pulled it. I did not think about the fact that when I turned the mechanical advance 180* it changed the dizzy 180*...I know I should have known that. Now in my defense I am going to tell you guys the same thing >SNIP
What am I still doing wrong? I still cannot get the rotor and the armature-stator to both align when the crank is at TDC (yes, I know how to find TDC)
thanks
If I do reinstall the distributor with the rotor 180 degrees around, am I going to discover that all three will now align so the armature/stator fires while the rotor is still on, not past/nearly past #1 post? (I'll go out and try it again, but I didn't get it right yet) Indeed, it is acting like it is firing "late"
thanks
Symptoms:
Now: backfiring out 2150 carb and exhaust, depending how much I fool with the distributor body position, won't start, or runs terribly and stalls quickly. Dry, sooty spark plugs.
Also, weirdly: When engine did run for short periods, got a noticeable buzzing from the C6 transmission? As long as the sound lasted, the engine ran (poorly). Soon as the buzzing stopped, the engine quit. If I disconnect the vac line to the C6, the buzzing stops, but engine still starts/runs like crap. (What's this?)
When it broke down: Was working great, then would not accept throttle at highway speed, Stalled, restarted, eventually would not start. Had spark, was getting fuel. Replaced module. got better spark, engine just cranked without starting. Tow guy said he hears valve popping through the carb and this means timing chain jumped a tooth. At 70K miles, it was at its streth limit spec, but the gears were still aligned properly. Replaced timing chain set (got the dots right at 6 o'clock and 12 noon). No better, well, it doesn't pop through the carb, at least.
Pulled valve cover and verified 1) #1 valves are closed at TDC, and 2) all valves move in time, so, camshaft isn't broken
During tear down, found stator broken. "Ah-Ha!" Replaced with recuilt distributor (Cardone) No luck.
Check all wiring, tested new module at each harness connector, etc. New AC Delco coil 9old one tested fine, anyhow). New fuel pump. Checked fuel system = OK.
New damper (Note: mistakenly bought and installed a harmonic balancer for the 351M, so its timing marks are way late than OE. for the 351W, But I did make my own marks on it at TDC, plus I have a dial-in timing light)
Rebuilt & adjusted the carb (created some seepage out the throttle shaft, both sides, but too little I think to perpetuate same symptoms)
Painted the crank pulley (Say, how can I now get it to align the belts, since the balancer for the 351M is 1/2 inch shorter in the pulley mount than the original?)
Checked all vac hoses, neutral safety switch, tightened intake manifold bolts, bought a bigger easy-up canopy, drank not enough beer, annoyed my neighbors, bewildered a former truck tech, was late for work twice this week for not getting to sleep on time.....
