Sponsored by: Real Truck
Caliper question
Old Mar 7, 2008 | 03:52 PM
shu5720's Avatar
shu5720
Not to change the thread topic but, already have the vacuum problem. Defrost only. Will be working on finding the leak this weekend. Since it is a V-10, it just has the vacuum solenoid? Am I correct to assume only the diesels have a vacuum pump? Again, thanks for all the help.
Old Mar 7, 2008 | 03:58 PM
bpounds's Avatar
bpounds
You probably already found the fix for that when you fix the auto hub vacuum leak. I think on gassers it all uses intake vacuum but I'm not positive. Don't know why they would need a second vacuum source. Anyway, the defrost only problem is the dead giveaway that you have a vacuum leak.
Bill (stick'n a plug in it now)
Old Mar 7, 2008 | 05:42 PM
Mercury45's Avatar
Mercury45
i suggest using a 1/8NPT plug into the knuckle, a nice brass one will do and this is what i did
and I unplugged the 4wd solenoid and actually ripped it out of my truck - this solenoid is located on the fender wall on pass side
kenny
BigOrange1977
Oct 2, 2014 09:22 PM
Sn00zer99
Aug 28, 2011 11:04 AM
todd jo
Jun 3, 2009 06:52 AM
bremen242
1997 - 2003 F150
Apr 13, 2009 08:09 PM
78250crewcab4x4
Offroad & 4x4
Jul 2, 2006 01:35 PM
