Sponsored by: Real Truck
Caliper question
Old Mar 6, 2008 | 06:54 PM
shu5720's Avatar
shu5720
Question Caliper question
Hey guys, I was rotating the tires on truck I just bought and noticed a problem. On the front calipers on my 2000 SD there is a hose going into a fitting to the rear of the brake line on each. Not sure where they go from there as it looks as if they just connect to each other? Like an equalizing tube?? The problem is the fitting on the passenger side is broken off. I dont even know what to call it to get the replacement. Any help on what these hoses do would be awesome. Is it a big enough issue not to drive the truck as is? Truck is 2000 F250 SD Scab 4x4 v10. Thanks in advance.
Old Mar 6, 2008 | 07:26 PM
redford's Avatar
redford
FTE Leadership Emeritus
"there is a hose going into a fitting to the rear of the brake line on each"
What is this hose made of? What is the fitting made of? Is there anything in the hose (fluid, wire, air, bugs)? What does the fitting look like? How big is the hose? What color? What color is the fitting?
Old Mar 6, 2008 | 07:31 PM
msgtg's Avatar
msgtg
Has your ABS light come on?
Joe
Old Mar 6, 2008 | 07:40 PM
shu5720's Avatar
shu5720
Sorry. The hose is rubber. Runs into the caliper. After doing some research, is this the vacuum line for the ESOf? Previous owner changed over to manual hubs. Joe, the ABS light did come on, but it was real low on fluid, after topping off, ABS light is out.
Old Mar 7, 2008 | 05:20 AM
msgtg's Avatar
msgtg
I really don't know...one of the pro's should chime in shortly.
Good luck Pal!
Joe
Old Mar 7, 2008 | 09:21 AM
bpounds's Avatar
bpounds
If it goes into the caliper, maybe the PO just stuck the vacuum hose on the bleed nipple? Is it just stuck on there with no clamp? Pull it off and see whats inside.
Bill
Old Mar 7, 2008 | 11:57 AM
Mercury45's Avatar
Mercury45
i think you are confusing the caliper with the knuckle... and it would then be the vac lines... just my guess though
kenny
Old Mar 7, 2008 | 12:12 PM
bpounds's Avatar
bpounds
A photo would be helpful.
Old Mar 7, 2008 | 12:17 PM
Mercury45's Avatar
Mercury45
yes it sure would be ^^^^ hes right
kenny
Old Mar 7, 2008 | 12:43 PM
shu5720's Avatar
shu5720
At work now, will check again. Maybe it is the knuckle. I will try to get a pick if it is not too dark. Not the bleeder screw though. Found that one.
Old Mar 7, 2008 | 03:23 PM
shu5720's Avatar
shu5720
My apologies. "upon further review" the hose is going into the knuckle, which as I understand it, would make it the ESOF vacuum line. I plugged it off as the PO switched over to manual hubs. Thanks for the help. I will be sure to work on looking at the part twice and then posting a question.
Old Mar 7, 2008 | 03:29 PM
bpounds's Avatar
bpounds
Another happy ending brought to you by FTE. We love you long time.
Bill
RussB's Avatar
RussB
make sure both ends of that vacc line is pluged !! I've heard that it will cause problems with your inside heater vents as they are ran on vacc as well. Others might be able to elaborate on that !!
Old Mar 7, 2008 | 03:42 PM
bpounds's Avatar
bpounds
It's probably not necessary to plug "both ends". But plugging one end of both hoses is a really good idea. Well, you did invite elaboration, LOL.
Whatever it takes to avoid a vacuum leak.
Bill
Old Mar 7, 2008 | 03:47 PM
RussB's Avatar
RussB
bpounds.. yes... sorry that is what I meant to say... just put a plug in it !!!! LOL
