Another Stroke Question
Old Mar 6, 2008 | 02:48 PM
opd's Avatar
opd
Pulled an FE form a parts 65 F100. Motor and trans were transplanted. The motor had Thunderbird valve covers and I was optimistic it may be a 390. It has 2bbl carb and a factory ac compressor that reads 1964 Ford air conditioning. Pulled the intake and head and measured the stroke and found it to be 3 3/8" if not a little less. The measurement doesnt match up with FE stroke info I have found on this site. Any guidance would be apprecitated, As anything less than 390 goes to the heap with the remains of the truck. Thanks in advance.
Old Mar 6, 2008 | 05:23 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
The early 332's had a 3.30" stroke. If you can get at the crank the 332 crank numbers are...
EDC for the 58
5752421 for the 59
COAE-C service replacement
Old Mar 6, 2008 | 07:01 PM
85e150's Avatar
85e150
Check the bore before you scrap it....
1999stroke
Jan 12, 2014 11:25 PM
toddspeed
Mar 21, 2013 11:35 PM
Mercmeister
Oct 5, 2010 09:32 PM
78fordranger
Apr 19, 2008 06:23 PM
masterbeavis
17
Nov 3, 2007 03:46 PM
