black shield under front bumper ? ? ?
Old Mar 5, 2008 | 05:24 PM
MiKeYs 2k DiEsEl 4x4's Avatar
Anyone ever take that off ?...does it have any purpose ?
Old Mar 5, 2008 | 05:32 PM
aortizexcursion's Avatar
aortizexcursion
I believe it covers the Blocker Beam which makes the Excursion more compatible to front end collisions with smaller cars, it prevents them from sliding under the Excursion. As far as removing it, in my opinion it won't look to good with a chunk of metal visible in the front of the vehicle.
Old Mar 5, 2008 | 05:35 PM
afreemanmd's Avatar
afreemanmd
prolly makes it slightly more aerodynamic in addition to hiding the blocker beam. (read down in the 6.4 forum about the job 1 versus job 2 airdam)
No real reason to move it as far as I can tell...
Old Mar 5, 2008 | 08:10 PM
dizzy d's Avatar
dizzy d
LOL that is the first time I have heard the words Excursion and aerodynamic together!
Old Mar 5, 2008 | 08:19 PM
aortizexcursion
My Jeep Wrangler and aerodynamics together is funny, its basically an oxymoron!
Old Mar 5, 2008 | 09:08 PM
dizzy d's Avatar
dizzy d
That is funny I have a 01 Wrangler Sport with only a 2 inch lift and 31s and if the top is up can’t get it over 80 on the free way if the top is down I can get it up about 85 or 90. With the top down it is not nearly as sketchy on the free way! And I get better MPGS in the Ex with the jeep on the trailer LOL! The jeep truly is a box on wheels.
Old Mar 5, 2008 | 09:46 PM
afreemanmd's Avatar
afreemanmd
Im serious!
https://www.ford-trucks.com/forums/6...-question.html
Some guys say +1 mpg lol
Just some food for thought.
I wonder if you could retrofit... I doubt it
Old Mar 5, 2008 | 11:34 PM
dizzy d's Avatar
dizzy d
Im serious!
You would scrape curbs with that thing! If you put a 08 front end on you could LOL! I think we would all love to see that!!!
Old Mar 6, 2008 | 10:53 AM
njstevens's Avatar
njstevens
I think it is ugly and not needed. As for removing the one currently on your vehicle I would say no for a few reasons. One is if you look behind it it is held with clips and bolted to 2 brackets at ends of blocker beam. So now you remove it you will see blocker beam ( maybe you could deal w that) but you will also see the brackets whcih woould stick out like sore thumbs. Now if you remove the backets then you will loose the capabilites of hlding up your blocker beam and I would not suggest doing that. If you were to get into an accident and you removed the blocker beam and someone got hurt do to you X sitting on them you could (potentially) be liable due to the fact you altered youyr veihicle safetly equipment. I recently had to cut that plastic and bracket to fit my new tires because I went with minmal backspacing on my new rims .
Old Mar 6, 2008 | 03:27 PM
Downriver Thunder's Avatar
Downriver Thunder
Mine was removed when the plow went on.
351slug
Offroad & 4x4
Mar 16, 2013 10:11 PM
Irish816
Offroad & 4x4
17
May 19, 2010 08:08 AM
Offroad & 4x4
Dec 9, 2006 09:03 PM
4x4x4x4
28
Dec 16, 2002 01:54 AM
CustomCab4x4
Feb 3, 2002 02:20 PM
