General Automotive Discussion
3.8 trouble
Old Mar 5, 2008 | 09:46 AM
IBOLD's Avatar
IBOLD
3.8 trouble
I know this is not a ranger problem but you guys have helped me on my ranger so much I thought I would ask your help on this!!! On my wifes windstar when you syart it up sometimes it will just die but if you start it and keep it reved up alittle it will go and then be fine!! it happens when hot and when cold the idle goes from 500-850 up and down I replaced the throttle pos sensor no help I sprayed cleaner on manifold to lok for vac lek did not find any no codes show up either any ides am I over looking a sensor that could cause this???? thanks for any help in advance and please overlook the fact this is not a ranger I just need some help bad momma is not happy so life is tough thanks
Old Mar 5, 2008 | 10:42 AM
Moore558's Avatar
Moore558
Since the IAC (Idle Air Control) valve is easy to get at on the 3.8/4.2, take it off and see how gunked up it is with carbon. If it is dirty you can try cleaning it and seeing if that helps.
Old Mar 5, 2008 | 05:29 PM
IBOLD's Avatar
IBOLD
3.8 trouble
thanks for the response I went out and took idle valve off it was not real bad but did have a carbon buildup cleaned it with carb cleaner and put it back on will let it set for a while and try it if it fixes it do you think I should replace it they cost $80.00 but will buy one if needed thanks mike
Old Mar 5, 2008 | 07:18 PM
fordboy_52's Avatar
fordboy_52
moved to gen auto
Old Mar 8, 2008 | 03:49 AM
IBOLD's Avatar
IBOLD
3.8 trouble
well I cleaned the idle control valve and that fixed the problem thanks for the advice no telling what the dealer would have charged thanks again
daniel5625
1983 - 2012 Ranger & B-Series
Jan 21, 2011 05:25 PM
zdewald
75
Jun 22, 2009 04:46 PM
NitroRCfan
Nov 16, 2006 10:53 PM
Jmorrell588
Jan 26, 2003 04:52 PM
Xizang11
Aftermarket Products
Jan 27, 2002 09:40 PM
