Very high idle problem!!
Old Nov 14, 2006 | 08:47 PM
NitroRCfan's Avatar
NitroRCfan
My 2000 Ranger suddenly developed a very high idle problem. It is so bad that it cant be safely driven. Not to mention the fact I fear tearing up the clutch or even doing engine damage on these cold mornings. I dont have a tach but to give you an idea, if you are going down the road in 5th gear, it will do 70 mph by itself. So far no check engine light. I have thorougly cleaned the throttle body and replaced the throttle postion sensor. For the heck of it I even unplugged the IAC just to see what would happen. Nothing changed! Anybody have any thoughts on this? Please help!
Thanks!
Old Nov 14, 2006 | 09:13 PM
RangerPilot's Avatar
RangerPilot
Check the throttle cable itself, sounds almost like it's stuck open somewhat considering you replaced the TPS and cleaned the TB.
Pull the intake tube and see if the throttle plate is fully closed. Also if you have cruise control pull the fuse for it.
Old Nov 14, 2006 | 10:30 PM
NitroRCfan's Avatar
NitroRCfan
The cable is working as smooth as can be. I will try taking the tube off tomorrow and see what the butterfly is doing while its running. Not equipped with cruise so that is eliminated. Thanks
Old Nov 15, 2006 | 09:06 AM
Rags's Avatar
Rags
Also Check for a vacuum leak at the upper intake like all hose connections or hoses themselves.
Old Nov 15, 2006 | 04:48 PM
NitroRCfan's Avatar
NitroRCfan
I just checked all the vacuum lines and could find nothing wrong. The throttle body is completely closed and stays closed even when its running. Could it be the IAC is bad? $110 for a new one! Ouch! Should I replace it or just take it somewhere?
Old Nov 15, 2006 | 04:50 PM
monsterbaby's Avatar
monsterbaby
check for vacuum leaks with something like brake clean or even wd40, when you find one the idle will change. Most common problem with high idle is unmetered air ie vacuum leak.
one place I have seen it escape notice is the brake booster, plug or pinch off the vacuum hose to the booster and see if it changes the idle any.
Old Nov 15, 2006 | 06:16 PM
Rockledge's Avatar
Rockledge
If it's a 4 banger, then consider this:
https://www.ford-trucks.com/forums/s...36&postcount=2
Old Nov 16, 2006 | 04:44 AM
NitroRCfan's Avatar
NitroRCfan
Thanks for all of your help on this guys! I found a new IAC at advance for $50. Problem solved! Thanks again for all of your input!
Old Nov 16, 2006 | 10:17 PM
SMiddleton's Avatar
SMiddleton
Iac
What is an IAC. I have a similar problem on a F-150.
Old Nov 16, 2006 | 10:53 PM
matt's2.9STX's Avatar
matt's2.9STX
IAC is Idle Air Control. There's a good tech artice linked from right under this website's top menu setup that applies pretty well in a general sense to most Ford trucks. There are other articles around the web, too.
jas88
Jun 16, 2021 06:43 PM
mike24150
Jul 5, 2013 01:42 PM
jawilla
May 5, 2009 07:44 PM
Mary_Kate_Olsen
1978 - 1996 Big Bronco
Oct 5, 2003 10:29 PM
ragoodson5
Jul 25, 2001 06:06 PM
