Replacing # 8
Old Mar 5, 2008 | 01:00 PM
F350-6's Avatar
F350-6
Originally Posted by 4inchlovin
What if i do this and mess up the UVCH? Then i will automatically need a new one. Is the UVCH also the VC gasket??? or are they two different pieces???
As always thanks for the help!
The UVCH (Under Valve Cover wiring Harness) is a separate piece. I don't have the part number handy, but it seems like they're cheaper from IH. The valve cover gasket is a rubber material that is re-usable.
Old Mar 5, 2008 | 01:21 PM
wlihntr's Avatar
wlihntr
the UVC plug could of just come lose as well, the tend to fall off from the back first. pick up some UVC plug clips from the dealer before you open it up (if it has not already been done) and install it while you are in there...just to avoid that problem comming up in the future if that is not the problem
POPAJON
Jan 12, 2015 06:00 PM
automaticj5
Oct 29, 2013 11:05 PM
48flthdf1
Jun 22, 2012 08:56 AM
chadg2
Escape & Escape Hybrid
Jun 13, 2008 09:43 PM
