well i still plan on doin it since its gettin all bubbly but with the lower ped o-rings leaking would it cuz it to run down the back of the oil pan... i thought that it would pool up in the valley??
Dryfly....at first i thought it was my oil pan since there is always oil on the back side of the pan and on my fumoto drain
alrite... i thought about doin an ebpv delete but i duno...i live in WI and think that it would be nicer to have my engine warm up quicker instead of letting it run longer its still in the air tho..but i do plan on replacing my lower o-rings
There's a drain hole in the valley, passenger side iirc. Oil leaks in the valley will eventually run down the back of your oil pan.
