30 lbs boost gauge enough?
Old Mar 4, 2008 | 11:44 PM
superduty4x4's Avatar
superduty4x4
I have a line on a new, unused Diesel Manor gauge kit with a 30 lb boost gauge for a decent price. Is 30 lb high enough though? At most, I plan on doing 6637 (got the filters today!), 4" turbo back exhaust, DP tuner, and stage 1's.
Old Mar 5, 2008 | 12:14 AM
white Buffalo's Avatar
white Buffalo
Yep, that's what I have - 30lb ISSPRO boost gauge. stage I inj, 6637 & van turbo.
Old Mar 5, 2008 | 12:17 AM
Layson's Avatar
Layson
If you ever plan on upgrading that turbo then you may want a bigger one..
Old Mar 5, 2008 | 12:24 AM
Tenn01PSD350's Avatar
Tenn01PSD350
This is true. Great looking truck Layson, I finally looked.
Old Mar 5, 2008 | 04:04 AM
imelmo's Avatar
imelmo
Are you not hitting over 30lbs of boost with your set-up?
Old Mar 5, 2008 | 06:45 AM
white Buffalo
Nah, between the WW and Diesel innovations intercooler (DIIC) I don't hit the 30 mark.
Old Mar 5, 2008 | 07:39 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I went with the 40 # gauge. If I hold WOT I can go a little over 30#. I usually feather the pedal keep around 25# untill I decide on the WW or ATS. Surge gets bad over 25#.
Old Mar 5, 2008 | 08:32 AM
superduty4x4
Since everything is new I may call DM and see if they'll let me swap the boost gauge, I'd like to have the 40 lb gauge too.
Old Mar 5, 2008 | 10:00 AM
imelmo's Avatar
imelmo
Ah, yeah, the intercooler will definately drop it down a little.
Old Mar 5, 2008 | 11:26 AM
white Buffalo
I think it was you, Luke and a couple others that gave me the advise on the intercooler @ 2 years ago. Glad I did it, especially when towing in the hills.......
Old Mar 5, 2008 | 12:20 PM
stormyrider's Avatar
stormyrider
If you are stock, wot normally is around 18 psi. At around 23 psi the computer starts to defuel to limit boost. With my setup I haven't seen over 18 psi yet even when towing.
Old Mar 5, 2008 | 07:24 PM
sflem849's Avatar
sflem849
30 is plenty. You lose readability the bigger the gauge.
superduty4x4
Dec 10, 2022 03:12 PM
wmiller
Mar 6, 2008 11:44 AM
cdiddy
Jan 4, 2008 11:38 PM
HzrInAz
19
Jun 20, 2003 07:57 PM
ryanben
All Things Towing
Apr 28, 2003 10:02 PM
