General Automotive Discussion
odd compression
Old Mar 4, 2008 | 12:50 PM
MisterCMK's Avatar
MisterCMK
odd compression
I've got a 97 Dakota at work here and it has the AMC/Jeep 2.5L OHV I4. It has no compression on 1 and 4, 2 has low compression and 3 is normal. I pulled the valve cover and all of the rockers look fine and everything is moving. I'll probably pull the head next here as I'm thinking a headgasket. BTW, the engine has 180k on it.
Old Mar 4, 2008 | 01:34 PM
fordboy_52's Avatar
fordboy_52
did you do a leak down test? i would do this before doing anything else. you might be able to get away with some top end work with the heads still on the motor.
Matt
Old Mar 4, 2008 | 07:03 PM
MisterCMK's Avatar
MisterCMK
The mechanic that we took it to first did and said that it was leaking out the exhaust and the crank case.
I pulled the head off this afternoon. Stick a fork in 'er. She's done.
Old Mar 4, 2008 | 08:17 PM
fordboy_52's Avatar
fordboy_52
how did u not hear that!? lol
Matt
Old Mar 4, 2008 | 08:26 PM
Ford_Six's Avatar
Ford_Six
Looks like the 390 from my 72. Or the engine in my old Escort. That one dropped a valve seat and blew chunks into the other cylinders back through the intake.
Old Mar 4, 2008 | 09:21 PM
Eagle460's Avatar
Eagle460
Exclamation
I fail to understand how you could not hear anything with the engine running, looks pretty bad. Ouch.
Do you plan on replacing the engine with another of the same make? What's happening?
Old Mar 4, 2008 | 09:23 PM
MisterCMK's Avatar
MisterCMK
Matt
The guy that was driving it said that it didn't make much noise and just turned off. I am surprised it wasn't more dramatic when the piston grenaded itself. Depending on when we can get a motor I'll post up pics of the oil pan.
Old Mar 4, 2008 | 09:40 PM
Ford_Six's Avatar
Ford_Six
It probably didn't make much louder of a noise than the detonation that caused the damage-
Old Mar 5, 2008 | 08:47 AM
MisterCMK's Avatar
MisterCMK
I'm not sure yet. I'm pricing out engines for the truck. We will probably end up putting another 2.5 I4 in there and getting it back on the road. That is the simplest and easiest route at this point and it means that we won't be looking at purchasing another truck.
Old Mar 5, 2008 | 08:48 AM
MisterCMK's Avatar
MisterCMK
Heh. I'm anxious to see what the piston looks like.
Old Mar 5, 2008 | 05:02 PM
rebocardo's Avatar
rebocardo
Wow. This brings up a point of all the cars on CL with 150,000+ miles with "just needs a headgasket"
I wanted to buy a cheap Trooper 4x4 with 202,000 miles for $500 (nuked tranny) and he gave me a bunch of hassle because I wanted to do a compression test before I bought it. Thinking now I will skip it, has an anti-freeze leak ...
Old Mar 5, 2008 | 05:09 PM
andym's Avatar
andym
Knowing Chrysler, they probably forgot to install the piston.
What was wrong with the other 2 cylinders?
Old Mar 5, 2008 | 09:55 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
What piston?
Old Mar 6, 2008 | 10:56 AM
MisterCMK's Avatar
MisterCMK
lol, I meant handful of spare parts in the crank case.
Old Mar 6, 2008 | 11:04 AM
fordboy_52's Avatar
fordboy_52
im guessing there will be a few pieces not much bigger than a quarter. the rest will be shrapnel
Matt
