CD changer
Old Mar 3, 2008 | 09:47 PM
Icefan71's Avatar
Icefan71
CD changer
The 6 disc CD changer isnt working in my 98 EB. When I try to use it it either says "no disc" or it runs thru each disc but doesnt play anything. Does it need a cleaning or is something not working right? Anyone ever have this problem before?
Old Mar 3, 2008 | 10:45 PM
madsonp's Avatar
madsonp
Are you sure you're loading the disks right side up ?
Old Mar 4, 2008 | 03:58 AM
JaySVX's Avatar
JaySVX
This happened to me at first. I had loaded the cd upside down in the changer cartridge. Also might want to see if it's set all the way down in.
Old Mar 4, 2008 | 08:55 AM
2000Expy's Avatar
2000Expy
My Kenwood 10 CD-changer crapped out recently. It won't eject from the unit, and won't play either. Damn shame, it's not really that old. I don't know if it's reparable or even worth it. I might just buy a new one.
Old Mar 4, 2008 | 09:27 AM
xxx609's Avatar
xxx609
This has happened to me a few times, usually during the summer months here in VA. My remedy is to remove the cartridge from the CD player; cycle the radio from CD to FM and back to CD; re-insert the cartridge. That seeems to work for me. I've heard people suggest a cleaning, but I'm not sure what constitutes a good "cleaning."
Old Mar 4, 2008 | 09:30 AM
2000Expy's Avatar
2000Expy
I wouldn't know how to clean something like that, unless you spray electronics cleaner in there. I'll try your method once I get the cartridge out, which is my problem.
Old Mar 4, 2008 | 11:31 AM
Icefan71's Avatar
Icefan71
First thing I checked was if the CD's were in the right way. xxx609, I'll try your suggestion and see if that does anything.
Old Mar 4, 2008 | 07:02 PM
madsonp's Avatar
madsonp
I figured so, but with some people you never know. Something else you might try is pull the changer, unplug it then plug it back in. They're pretty easy to pull.
Old Mar 5, 2008 | 04:00 PM
Icefan71's Avatar
Icefan71
609, your idea worked. Not sure how, but its working again. Thanks!!
juicejr33
Sep 5, 2013 03:08 PM
rnnrrnnr
Feb 13, 2012 04:52 AM
rel3rd
Dec 3, 2006 09:32 AM
wyldbillracer
Dec 31, 2004 10:08 PM
