Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
The Beginning...
Old Mar 3, 2008 | 07:41 PM
96sherm's Avatar
96sherm
The Beginning...
well i had some daylight hours today so i got a start on my '83... got the carb off for a rebuild. figure i can save a few bucks and rebuild this one instead of buying a holley or something.
can anyone decipher the tag from the carb??
here it is, L 4 82, VAE 3, E3UE DA...
i'd like to know if its a 2100, or 2150 motocraft...
Old Mar 3, 2008 | 07:46 PM
51dueller's Avatar
51dueller
That will be a 2150. The 2100 was discontinued in the late 60's/early 70's. Anyways they use most of the same parts.
Look on the side of the carb under the power valve linkage. The number here will list the venturi size. It's most likely a 1.22.
Old Mar 3, 2008 | 07:47 PM
96sherm's Avatar
96sherm
cool. thanks nathan, i was hoping you'd chime in. carb kit run about 40-60 bucks?? fairly simple to do??
Old Mar 3, 2008 | 07:50 PM
51dueller's Avatar
51dueller
These carbs are very simple to work on.
Here's some good info on what the parts of the carb are:
http://home.earthlink.net/~bubbaf250...rb/carb02.html
It's several pages but it's a good read.
Old Mar 3, 2008 | 07:54 PM
96sherm's Avatar
96sherm
hey maybe you could answer this queston easily, after reading that article, is seems that rebuilding this carb would be way better off than buying a holley or eddie...so...is my air gap intake a paperweight now?? any way i can mount the 2150 on the performer intake? i didn't look at the holes...
Old Mar 3, 2008 | 08:09 PM
51dueller's Avatar
51dueller
Probably the easiest would to get one Edelbrocks Ford EGR spacers like this:
Then just get a plate to block the EGR.
Old Mar 3, 2008 | 08:13 PM
96sherm's Avatar
96sherm
hey alright!!!! where would i find one of those, and next question, how much benifet to doing it??
Old Mar 3, 2008 | 08:23 PM
51dueller's Avatar
51dueller
You should be able to get the adapter plate anywhere they sell Edelbrock products which is just about everywhere!
Now to be worth it is the next question. It all depends on what your planning on doing to your engine. The 2150 works pretty darn good for what it is. For example if you do put a bigger camshaft in, the 2 barrel will still work up to a point. It'll pretty much be just a rev limiter as it can't sustain the fuel requirements for higher RPM. The 2150 will be a good setup to cut your teeth on and if further modifications/needs require, the 4 barrel will just be a bolt on away.
Old Mar 3, 2008 | 08:24 PM
Dustin1690's Avatar
Dustin1690
Sounds like fun fun sherm good luck buddy
Old Mar 3, 2008 | 08:27 PM
joewaldner's Avatar
joewaldner
you're fixing the brown one in your gallary?
do you have the other hubcaps for the back lol... I have a set of those... for $20
or a set of 5, 8spoke steel rims, with 4 black center caps (need good sanding and paint)
this style --> http://nevcustom.com/images/12x4Steel.jpg (they dont have the button things to attach the center caps (punched out), I was asking $75 for all 5 rims and 4 caps,....
also have a almost-new chrome front bumper, grill and light surrounds $250
(actual pictures of the parts)
http://i5.piczo.com/view/1/6/d/e/q/2...29_75087_5.jpg
http://i5.piczo.com/view/1/6/d/e/q/2...30_88746_5.jpg
http://i5.piczo.com/view/1/6/d/e/q/2...527_6661_5.jpg
Old Mar 3, 2008 | 08:28 PM
96sherm's Avatar
96sherm
thanks dustin. well for now i'll just stick with the 2bbl 2150, and i see i can get the adapter plate easy enough so i think i will put the intake on there. i had planned on a cam, but i've toned down my thoughts for now. i'm going budget and going to get her running sweet and stock before playing too much. that being said, any noticeable difference between the stock intake and the performer i have??
Old Mar 3, 2008 | 08:30 PM
96sherm's Avatar
96sherm
yeah i'm going to put some time into her... those rims won't cut it but thanks anyway. i'm going for 295/50r/15's
Old Mar 3, 2008 | 08:45 PM
51dueller's Avatar
51dueller
For the differences in the intakes, I can't answer that. I don't have much info about the carbed stuff. I've put more interest in the EFI parts so I guess you will have to find out yourself.
Old Mar 3, 2008 | 08:46 PM
96sherm's Avatar
96sherm
that i will do. thanks for the direction to that conversion plate though. i found it at Jegs, runs about 49.99... i'll see my parts guys tomorrow to order the rebuild kit for the carb and ask if they can get that plate...
Old Mar 3, 2008 | 09:01 PM
preppypyro's Avatar
preppypyro
I must be missing something. Whats the reason you are sticking with a 2 barrel over a 4 barrel?
I kinda assumed you were doing the engine up abit just from some of your other posts, and if so, a 4 barrel would be the way to go over a 2 barrel anyday!
Im not saying to go get the biggest 4 barrel in the world either!
Plans changed, or am I missing something?
