how much horsepower?
Old Mar 13, 2002 | 04:59 PM
smooth yellow's Avatar
smooth yellow
[updated:LAST EDITED ON 13-Mar-02 AT 06:50 PM (EST)]Hi ,
could someone tell me how much horsepower and torque this combo would have, approximately?
400 bored 30 over with ohio flat tops, comp 268H-10 cam, Edelbrock Performer 400 manifold and Edelbrock 600 CFM carb and .0025 shved off the stock 78 CC heads also has a 3 angle valve job and mild port work.
any info would be great, thanks
Mark
Old Mar 13, 2002 | 05:36 PM
Mil1ion's Avatar
Mil1ion
Welcome to FTE !
I wish I could help you .
BUT, You have typed in Upper case ( All Caps)
**Please** refrain from posting in all caps.
For one thing it is Very Difficult for some people to read.
(i'm one of them )
The other is , On the internet it is considered Yelling.
Not everyone knows this.
Once people see upper case they usually pass on it.
You will notice everyone else types in Lower case for these reasons.
You may edit your post to lower case within an hour of posting.
Thank you for your consideration.
Dennis https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=1733&.jpg
[i][font color=red]Calgary,Alberta,Canada[/font][i]
[font color=blue]Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [font/]
78 F-150 429CJ,Silver, Explorer Pkg.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon
Old Mar 13, 2002 | 05:52 PM
Franklin2's Avatar
Franklin2
[updated:LAST EDITED ON 13-Mar-02 AT 06:54 PM (EST)]Hi,
Could someone tell me approx. how much horsepower and torque this combo will have. And estimated compression ratio. 400 with Ohio piston flattops comp 268h-10 cam, Edelbrock performer manifold and Edelbrock 600cfm carb and .0025 shaved off the stock 78cc heads. Also has a 3 angle valve job and mild port work.
Any info would be appreciated. Thanks.
Mark
PS
I fixed your post so maybe Dennis will have intelligent info to relay to you.
franklin2
Old Mar 13, 2002 | 05:53 PM
smooth yellow
Dennis ,
thank you for the advice ! I had know clue.
thanks, Mark
Old Mar 13, 2002 | 05:56 PM
Franklin2's Avatar
Franklin2
Whoops, you beat me to it!
Old Mar 13, 2002 | 06:38 PM
83f2504x4's Avatar
83f2504x4
Well i ran what i could into the desktop dyno 2000. im guessing the milling and those pistons will put you right at 9.5:1 (someone correct me if im wrong), so i put that in along with small tube headers. it showed peak hp to be 377@5000 and torque was 440@3500. that should give you an idea at least.
Old Mar 13, 2002 | 06:49 PM
smooth yellow
gallery,
thank you for doing that, do you know how much can be taken off the heads w/o going to far? and do i need different push rods
thanks mark
Old Mar 14, 2002 | 08:23 AM
MrMotorsport's Avatar
MrMotorsport
I believe the max you can mill the heads would be .040 to .060, but you will need to consider two things: First, you may need to mill the intake manifold to keep port alignment correct. Milling the heads, in effect, causes the manifold to sit "higher". As for pushrods, no, you won't need new pushrods unless you get crazy with the milling. However, you will need the appropriate rocker stand shims to compensate for head milling. If you mill .030, then you will need .030 shims to keep rocker at the correct height. hope this helps.- Don
Old Mar 23, 2002 | 07:14 PM
4 Jaw Chuck's Avatar
4 Jaw Chuck
I wouldn't take any more than a skim cut on those heads, they are real thin. 0.010"-0.015" MAX!!!!!
Old Mar 23, 2002 | 07:19 PM
xyfalcon500's Avatar
xyfalcon500
sthrnredneck
Jan 21, 2005 09:49 AM
71FoMoCo
15
Mar 10, 2003 01:00 PM
chevykiller
Jan 14, 2003 07:41 PM
78orangeford
43
Sep 16, 2001 07:08 AM
tra
Feb 21, 2001 03:31 PM
