Old Mar 3, 2008 | 03:47 AM
jd58's Avatar
jd58
can someone tell me the cfm on the 4180 on a 86 f250 w/460
Old Mar 3, 2008 | 01:34 PM
Handegard's Avatar
Handegard
I believe I recall the 4180 being a 575cfm carb...
To add, I'll be replacing my 4180 with a 600cfm Edelbrock, hopefully this evening.
Old Mar 3, 2008 | 09:48 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The 4180 on 460's was rated @ 600 cfm,
I believe the 4180's in the 5.0 mustangs were 580 or so.
There's even a 675 model.
Check the #'s, I think there's a sticky on the fuel delivery board.
Old Mar 3, 2008 | 09:53 PM
jd58's Avatar
jd58
Thumbs up 4180
Thanks for the info
Old Mar 3, 2008 | 09:55 PM
Bear 45/70's Avatar
Bear 45/70
Engine size can effect the flow capacity of a carb. Example, back in the early 60's the 406 and the 390 both had the exact same 3X2 barrel setup. The 406 was rated at 920 CFM while the 390 was rated at 860 CFM. This is the auto manufactures only. The rated CFM of a carb from most carb manufactures is 4 barrels are rated at 1.5" hg (vacuum) and 2 barrels are rated at 3"hg.
Old Mar 3, 2008 | 10:02 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I had no idea that a 2 barrel would be measured at twice the vacuum
Old Mar 3, 2008 | 10:09 PM
Bear 45/70's Avatar
Bear 45/70
There is a formula to convert 4V to 2V and 2V to 4V so you can compare on a level playing field.
Old Mar 3, 2008 | 10:26 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I'm familiar with fluid dynamics and can find the answer. The formula's in Vizards book.
But why..3 inches of mercury v/s 1.5?
Old Mar 3, 2008 | 11:04 PM
Bear 45/70's Avatar
Bear 45/70
With the same engine CID at the same WOT rpm the the 2V engine will have a higher vacuum than a 4V will because of the smaller cross sectional area of the throttle bores and the venturi areas and that's the reason as told to me many years ago by a Holley tech guy at a Nationals drag race in Tulsa.
Old Mar 4, 2008 | 04:20 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Thanks Bear,
This makes some sense, but logically one would size the carb to displacement, and rpm range unless restricted by race rules.
Guess I'm too ignorant to think this way, and had figured manufacturers would compare 'apples to apples.'
Sorry to hijack......
Tkc432
Mar 5, 2016 09:26 PM
GeneGregory
May 24, 2015 10:25 AM
joe460
Mar 22, 2006 09:56 AM
Zoomie331r
Aug 19, 2004 05:21 AM
oldhalftons
Apr 4, 2004 08:46 PM
