C6 shift kit install
Old Mar 3, 2008 | 12:18 AM
brthevio's Avatar
brthevio
Has anyone on here actually done this themselves? I am looking to put one in my son's truck but would rather do it myself if it isn't a complete nightmare. I do have plenty of mechanical experience just none with transmissions other than changing them. Any special tools needed for this? How long does it take? Any info someone who has done it or knows where there is a site that walks you through it would be great. Thanks for any help that is provided.
Old Mar 3, 2008 | 05:04 AM
stuart1's Avatar
stuart1
It isn't rocket science.
The worst part is dropping the pan.
There are various bolt lengths so pay attention.
A digital camera is worth it's weight in gold.
This is one method for keeping stuff separated.
Old Mar 3, 2008 | 09:37 PM
projectnitemare's Avatar
projectnitemare
They are not bad. The biggest thing you need to look for when taking the valve body apart it don't loose the check ***** and look to see where they go. Aside from that it is pretty straight forward with what the kit will tell you. I've installed shift kits before I started working at a transmission shop, they aren't hard.
Matt
Old Mar 3, 2008 | 10:27 PM
brthevio's Avatar
brthevio
B&M makes a shift kit and a Transpak kit. Which would be easier? Do the ***** just fall out when you take it apart or am I going to have a chance to really study it and make sure I can put all of them back where they go? Thanks again for the info.
Old Mar 4, 2008 | 07:40 AM
stuart1's Avatar
stuart1
First I would stay away from B&M.
Nothing is going to leap out and get you.
There a few small screws on the upper portion of the valve body that should be removed first.
Again, pay attention to the length.
Now flop it over and remove the remainder.
Separate the halves.
The should be a ball on top on a sping and a flat valve on top of another spring plus one loose ball.
The separator plate on the lower portion can be removed and there may or may not be one or more ***** in there.
Save the old gasket if possible to match it up against the new one.
Old Mar 6, 2008 | 04:46 PM
asltrfl's Avatar
asltrfl
I'm Scared!
Old Mar 7, 2008 | 04:07 PM
brthevio's Avatar
brthevio
What brands would you recommend?
Old Mar 8, 2008 | 06:35 AM
stuart1's Avatar
stuart1
A Transgo -2 is the best I have seen for a C6.
xmontex4
May 16, 2014 09:43 PM
makthenif
Jun 1, 2011 09:23 PM
cyclecr8zy
Dec 29, 2007 09:42 AM
