1978 - 1996 Big Bronco
idle problems
Old Mar 2, 2008 | 11:05 PM
60FordDriver's Avatar
60FordDriver
idle problems
My 90 Bronco won't stay running. To drive you have to massage the gas and brake to keep it around 800 rpms. I searched the forum read up but did'nt see any problems like this. Check engine light is on. So IAC, ignition module, etc? Thanks.
Tony
Old Mar 3, 2008 | 05:59 AM
b4hntn's Avatar
b4hntn
You can pull codes without the engine running.
Old Mar 3, 2008 | 08:25 AM
Kemicalburns's Avatar
Kemicalburns
www.fordfuelinjection.com has instructions for pulling codes using a paperclip and counting the blinks. its not hard but necessary before you start throwing money at it.
Old Mar 3, 2008 | 06:17 PM
blue beast's Avatar
blue beast
Pull the Iac, Hold the solenoid dealy up and spray the valve area out with carb cleaner
move and spin the valve so you get all sides of it. let it dry, put Rtv on it and silver
antisieze on the bolts. The TPS wires should point to the Iac roughly if they are
way off you will need to check and set the tps voltage. What does it idle at with
the IAC unplugged? You may need to adjust the hard throttle stop if it backed off
you could have some wacky idle issues.
Ratsmoker
Nov 15, 2002 08:17 AM
Hwy Apostle
Oct 11, 2002 01:42 PM
Mikeman
Aerostar
Feb 10, 2002 06:17 PM
Blue coyote
Bronco II
Jul 31, 2001 11:36 PM
tuffguy
Offroad & 4x4
Jul 25, 2000 10:33 PM
