Aerostar Ford Aerostar
engine problem
Old Feb 7, 2002 | 02:18 PM
Mikeman's Avatar
Mikeman
engine problem
Old Feb 10, 2002 | 02:48 PM
dougas's Avatar
dougas
engine problem
1990 4.0 Aerostar
There is gas in the oil, turned oil blue. What would cause this? Please explain in detail.
Thanks
Old Feb 10, 2002 | 06:17 PM
asavage's Avatar
asavage
FTE Community Team
engine problem
> 1990 4.0 Aerostar
Blue? Weird.
My two cents, and only guesses:
1) Failed fuel pressure regulator diaphragm (maybe)
2) One failed injector (leaks excessively when engine is turned off)
3) Failed vapor/liquid separator in the fuel tank vent system
I'd expect both Nos. 1 & 2 to affect the way that the engine runs, especially startup after being shut down for only a few minutes.
On most carbureted engines, you'd be looking at a failed fuel pump diaphragm, but that doesn't apply to yours.
Sorry that I can't explain in detail. I hope somebody else has better guesses.
Regards,
Al S.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
