I have one of those with a crank at one end "to allow balancing the powertrain on the engine crane".
Honestly, I don't use it very much as I have a large hook on my engine crane therefore I can loop more than two chains - by using three or four chains I can adjust the lengths appropriately to get a specific angle when pulling or installing, and for me that works just fine.
No Frederic, This is more like a gantry that sets just inside the hood recess on the fenders at either side of the engine bay. You can 'hold' the engine up off the crossmember and remove the motor mounts, ect.. while the engine "levitates"
At work we have an OTC one and an ATD one. I've never personally used the OTC, but the ATD works well. I would recommend the ATD one over the northern tool one just for the fact that the ATD one has more adjustments to it. It appears that the northern tool one is limited to where you can hook the motor. Its model number is ATD-7477
Ooooooh, okay. I only glanced at the picture and immediately imagined it attaching to a crane.
I guess I haven't enough different timing belts to where a lift was a necessity much less an engine support. I own a support but never used it for a belt. In a pinch I found a 4X4, a chain and a small floor jack worked good to support an engine and lift it.
