AC compressor clutch not engaging
Old May 20, 2016 | 08:17 AM
coolfeet's Avatar
coolfeet
I had a mechanic replace the manifold hose and drier accumulator on my E350 dual AC van. Last night I pumped the system down to recharge it and noticed the compressor clutch is not engaging. We checked the plug to drier by jumping it. He said the compressor should kick on.
I pulled the connector to the compressor and reinserted it.
I had an intermittent problem with the compressor clutch not engaging and I could get it to work by wiggling the connection to the compressor.
Any ideas of what I should check?
Old May 20, 2016 | 09:41 PM
jimandnena's Avatar
jimandnena
Have you added refrigerant? Usually after pulling a vacuum, the system will take a whole can of gas. There must be enough gas pressure to close the pressure switch on the drier. As the rest of the gas is added, the compressor will cycle rapidly until there is enough gas in the system for normal cycling. Running the compressor with no gas will ruin it.
Old May 21, 2016 | 06:43 AM
JWA's Avatar
JWA
As Jim suggests if the refrigerant gas pressure isn't sufficient to engage the low pressure cut off switch that could one problem. You have charged the system again yes?
Not sure about the "had an intermittent clutch engagement issue"---does that exist now, does wigging the connector "fix" it?
If none of these ideas help visit the Cooling, Heating & Ventilation forum, look for member ProjectSho89----he has a somewhat extensive FAQ in the Tech Folder there that includes a quick check list. He does discuss the issue of the A/C clutch air gap being set properly which could be part of your current problem.
HTH
evdrummer
Jul 26, 2015 07:01 AM
littlered150
1997 - 2003 F150
Dec 5, 2012 08:59 PM
michaelbrainardatwor
Dec 9, 2007 08:01 AM
flbob220
Mar 13, 2006 02:14 PM
puckee
Apr 11, 2004 10:43 PM
