using a switch on 10k
Old Mar 2, 2008 | 11:28 AM
fatcathp's Avatar
fatcathp
is it possible to hook the 10k on a three position switch? to inside the cab? would that create to much resistance? it gets cold here in mich. and i havent done the 10k yet just worried about cold starts.
Old Mar 2, 2008 | 11:34 AM
Power_Hungry's Avatar
Power_Hungry
Former ******
No problem on using a switch. Many folks do that. Just keep the wire runs as short as possible.
Enjoy.
Bill
Old Mar 2, 2008 | 02:12 PM
tjbeggs's Avatar
tjbeggs
You can use a switch with the bypass method of the 10K but not on the inline method.
Old Mar 2, 2008 | 02:29 PM
Hussler's Avatar
Hussler
Short runs on wires are not necessary, very good connections are. 100 feet of 20 guage wire only measures .. maybe 0.5 ohms so in the scheme of things with the 10K mod that is really nothing.
Old Mar 2, 2008 | 03:14 PM
fatcathp's Avatar
fatcathp
tbeggs you were saying not a in line method. are you talking about a two position switch? would the bypass method be a 3 position switch? also how long do i have to be on this site before i can pm some one?
Old Mar 2, 2008 | 03:18 PM
Aberasturi_c's Avatar
Aberasturi_c
what would this mod do for my truck performance wise? Already have 4" turbo back mbrp,Afe intake and EDGE Evolution. Sounds like a quick easy way to do upgrade just wondering what will come out of it.
Old Mar 2, 2008 | 03:21 PM
WALJON's Avatar
WALJON
x2
tjbeggs's Avatar
tjbeggs
There are two methods to do a 10k mod on the ICP sensor. One is to jumper between two wires, that is the bypass method. There is a inline method of adding the resistance where you splice into one wire on the ICP sensor.
Being able to add a switch for on/off or other resistance levels can only be done in the bypass method otherwise a switch will have a momentray open in the circuit which will cause problems in the inline method.
I think PM's come after 25 posts but not sure.
Old Mar 2, 2008 | 03:38 PM
Hussler's Avatar
Hussler
Just did mine today but went with 12K .. why, because I'm cheap and that is what I had. I have no mods yet except FPR shim.
On startup had about 100 RMP increase, cold, but lasted only a few seconds. Big improvement was low end throdle response, more like a gasser .. not quite as cautious to jump out in traffic as before. When engine was cold and coasting towards stop intersection engine kind-of sounded different, maybe a little huffing thing. Once warmed up that went away.
Jim
Old Mar 2, 2008 | 03:51 PM
fatcathp's Avatar
fatcathp
ok well i will put all this info to use i appreciate all your inputs thanks
Old Mar 2, 2008 | 05:01 PM
WALJON's Avatar
WALJON
I have cold start issues with this mod and with some help tried some switches (I am talking the in line way) what works for me is a 10k potentiometer I can turn it off and set it to where I like without setting the cel
Old Mar 4, 2008 | 05:23 PM
IDMooseMan's Avatar
IDMooseMan
Ok, I gotta ask this question now because of some problems others have had.
I read that it is ok to unplug/disconnect the ICP (which sets the CEL) and run the engine/drive the truck. This sounds like it creates an "open" circuit that is much longer than momentary. Reconnecting the ICP clears the CEL (right?).
If unplugging the ICP and driving the truck is ok, why is wiring the 10K inline with a switch not ok? Again, we're talking about a momentary open condition that sets a CEL, but wouldn't the CEL clear when the ignition is turned off?
Old Mar 4, 2008 | 05:42 PM
tjbeggs's Avatar
tjbeggs
Because unplugging the ICP is done when the truck is not running. If you switch it or unplug it with the truck running it will quit and you will have to restart it.
Old Mar 4, 2008 | 08:21 PM
Hussler's Avatar
Hussler
The computer "PCM" looks at the sensors thousands of times per second. Just flipping a switch makes a quick disconnect / connect, but the computer will catch that open state on the switch and throw a CEL.
rat49f6
Apr 2, 2009 05:57 PM
littlejohn6977
Feb 7, 2009 10:45 PM
macho3035
Modular V10 (6.8l)
28
Jan 21, 2005 11:37 PM
countrysF250
13
Nov 10, 2004 11:59 AM
96ford4x4turbodiesel
Oct 18, 2004 11:00 PM
