351 4bbl
Old Mar 2, 2008 | 08:45 PM
ssidney's Avatar
ssidney
Originally Posted by baddad457
They weren't unique, same basic carb was used first on the 83-85 Stang HO 5.0. Truck 390's never got 780 cfm Holleys, if there was one there, someone other than Ford put it there. 390's only got 600 cfm carbs from Ford. The 428CJ's and a few other Hi-po Fords got 735's. I think one of the hi-po 429's might have gotten a 780, the Boss 302's did as well.
the 780 came off a truck (really) with a 390.....early '70's 5ton...and by unique for the truck I mean the way its set-up...just bought one for my '87...$450.00 same type of carb but generic from same dealer $350.00
Old Mar 2, 2008 | 08:47 PM
baddad457's Avatar
baddad457
Not even the F600, 700's and 800's used a carb that big from the factory. If it was there, someone other than Ford put it there.
Old Mar 2, 2008 | 08:50 PM
ssidney's Avatar
ssidney
that could very well be, I just checked using # off carb...the engine was actually a 391 (industrial 390)if it makes a diff.
Old Mar 2, 2008 | 08:55 PM
baddad457's Avatar
baddad457
The FT's(391 = FT engine, same basically as a 390, but different internals & heads) usually had smaller carbs than the others. These were built for low rpm pulling and didn't need a big cfm carb.
Old Mar 2, 2008 | 09:04 PM
ssidney's Avatar
ssidney
I guess someone really goofed putting that one on then
Old Mar 3, 2008 | 06:56 PM
Beanscoot's Avatar
Beanscoot
I pulled a small Holley 4V off of a 477 Super Duty engine in a scrap yard some years ago, it turned out to be 370cfm.
After removing the governor stuff and making linkage I put it on a 260, where it performed much better than the bigger (600cfm?) carb that it replaced.
The big truck Holleys are quite distinct with the governor controls, idle circuit on the secondaries, two power valves, cast iron base plates etc. However they do make great carbs for small V8s with some (a lot) of work.
jwtimme
Oklahoma Chapter
Dec 28, 2013 09:02 AM
beforeiforget761
2004 - 2008 F150
19
May 27, 2008 08:30 PM
STGFordCrazy04
South Carolina Chapter
May 7, 2008 06:42 AM
Mil1ion
Dec 19, 2003 12:02 PM
Greywolf
Tennessee Chapter
Feb 2, 2002 10:42 PM
