351C build decisions
Old Mar 10, 2008 | 07:14 AM
  #31
danlee's Avatar
danlee
Originally Posted by EFM
Will stock pusrods be ok or would
u recommend hardened?
You can use stock pushrods with this kit.
Old Mar 10, 2008 | 07:34 PM
  #32
EFM's Avatar
EFM
What I Meant Was Will The Stock
Pushrods Hold Up With The Lunati
Cam And 6000 Rpm
Old Mar 10, 2008 | 08:40 PM
  #33
danlee's Avatar
danlee
I used Trick Flow hardened pushrods, but I didn't need them. If your existing pushrods are in good shape, they should hold up. It wouldn't be a bad idea to replace a set of pushrods that have been in the motor for a lot of miles. You can get a set of Comp Cams steel pushrods from Summit for under $40.00 plus their 'handling charge'. I don't think that I have a set. I must have sold them or reused them. I'll check tomorrow.
ladiabla74
17
Dec 25, 2015 07:02 AM
voodoosurfer
32
Jan 10, 2006 12:52 AM
jesse1385
Jan 20, 2005 02:42 PM
bbtkd
Oct 15, 2002 12:00 PM
Brian S
Jun 25, 2002 09:28 AM
