ladder bars?
Old Feb 28, 2008 | 04:07 PM
Tim Shultz's Avatar
Tim Shultz
ladder bars?
alright, since my truck could REALLY use a set of ladder bars, and I don't have the cash right now to BUY a set, I'mma make a set.. two questions though, first, would a class II top link be strong enough? (my truck ain't makin' all that much HP) second, where could I find a bracket to pin the hymes sp? joint to? (that would then bolt/weld onto the frame and axle)
my plan was to cut two top links in half, then slide them into a 4 foot chunk of thick walled pipe and weld/bolt then onto the pipe.. I'm thinking it would work pretty good.. these would NOT be used for daily driving..
Old Feb 28, 2008 | 04:40 PM
Action4478's Avatar
Action4478
Is ...this ...what you are aiming for ?
Old Feb 28, 2008 | 04:49 PM
Tim Shultz's Avatar
Tim Shultz
thats a bit MORE Then I was aiming for.. I'd just have one pipe.. should work, my trucks not makin' no 1,000 foot pounds or nothin'...
Old Feb 28, 2008 | 07:59 PM
plowhand's Avatar
plowhand
Playing in the Dirt
For ladder bar parts look here: http://www.jegs.com/webapp/wcs/store...10065_-1_10057
Old Feb 28, 2008 | 08:35 PM
fishmanndotcom's Avatar
fishmanndotcom
i had your same idea/problem back after i put my injectors in. so i started hunting around my shop looking for ways to keep the wrap under wraps (so to speak). i found an extra tractor link i had laying around as a spare for our kubota. i cut it in half and welded some extra DOM tubing i had left over from my roll cage build to extend the links to the desired length. then i used some 1" square tubing to add some reinforcement. the front portion is not bolted solidly to the frame. instead i used a tension shackle system (found on all of our trucks from the factory on the rear leaf packs) that will keep the axle from wrapping but at the same time will still allow axle articulation and movement. i did the same thing for my bronco which i have yet to have a problem with!
-cutts-
Old Feb 28, 2008 | 10:18 PM
Tim Shultz's Avatar
Tim Shultz
looks GOOD! thanks for the pictures!
Old Feb 29, 2008 | 07:13 AM
tjbeggs's Avatar
tjbeggs
Cutts how long have you been running those? also did you remove the sway bar from the rear axle?
88f150kid
Feb 17, 2013 11:39 PM
oreocreaming
Nov 29, 2010 06:42 PM
sflem849
33
Feb 16, 2008 07:45 AM
Rancho*Ryda
Feb 1, 2007 10:52 PM
Franken-Truck
Offroad & 4x4
23
Oct 10, 2005 10:07 PM
