Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
air compressor hose diameter?
Old Feb 28, 2008 | 12:43 PM
ironmine's Avatar
ironmine
Looking at impact guns, etc for a new air compressor I'm buying, most of the model's specs require a *minimum* hose diameter of 3/8". Is there any advantage to buying bigger hose ... 1/2"?
Is it a function of hose length? I have not decided, but I will probably buy a 25' reel of hose, possibly 50' for more access out to the driveway.
i guess good 'ol rubber hose is the way to go? Lays flat? Remains flexible in cold weather?
Thanks for any info
Old Feb 28, 2008 | 02:52 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
3/8" hose usually has 1/4" couplers, reducing flow.
It really depends on how many CFM the tool demands. It is a function of length as far as friction goes. For a 1/2" impact gun on 50' of hose you should be fine. Rubber hose is perfect for garage work, it does lay flat and is abrasion resistant. PVC less so. The thin ureathane ones are nice for construction but not very durable in the garage.
Old Feb 29, 2008 | 01:56 PM
IDMooseMan's Avatar
IDMooseMan
The bigger your compressor tank, the less cycling your compressor motor will need to do to supply the tool with the proper operating airflow/pressure.
Old Feb 29, 2008 | 11:55 PM
Eric C.'s Avatar
Eric C.
3/8" hose will operate anything up to 1/2" impacts just fine as long as your compressor is big enough with a big enough tank. For 3/4" and 1' Impact I prefer 1/2" inch with detroit/claw fittings but these require dedicated line with a shut off valve and be sure to use the retainer clips. This is normally overkill for the average home or shade tree mechanic but then I do a lot of heavy duty work.
Old Mar 1, 2008 | 10:25 AM
rebocardo's Avatar
rebocardo
Yes, as a matter of fact I am ditching my 3/8 unless I can find a way to go to bigger then the 1/4" connectors on my impacts. It is a serious restriction with a 120v compressor.
Old Mar 1, 2008 | 08:03 PM
havi's Avatar
havi
I'll have the Roast Duck
Praxair sells the 3/8" fittings designed for 1/4" tools. Doing this allows me more air through the same 3/8" hose. You won't find'em at Menards or Northern Tool. My .02
Old Mar 2, 2008 | 12:33 AM
fixnair's Avatar
fixnair
Most tools have 1/4" pipe connections, so 1/4" fittings usually are adequate. The big restriction is a long legnth of 1/4" hose. Doubling the hose size increases the flow rate by a factor of 4. Therefore increasing the hose size by 50%, the flow rate is increased by a factor of 2. In other words 3/8" hose flows twice the air as 1/4" hose for a given legnth.
What I do to utilize my tools to their fullest is increase the operating pressure of my supply up to 150 PSIG. That way I am sure of getting at least 125PSIG at the tool.
Old Mar 2, 2008 | 08:18 AM
brownieboy525's Avatar
brownieboy525
Harbor frieght has a few very good deals on goodyear rubber air hoses. i bought some cheap pvc hose when i first got my compressor and the pvc hoses are junk. THey dont roll up easy and the connectors have blown off a few times, and when its cold out dont even think of bending them or moving them around.http://www.harborfreight.com/cpi/cta...emnumber=30268
http://search.harborfreight.com/cpis...ibuteSearch.do
Old Mar 3, 2008 | 12:10 AM
rebocardo's Avatar
rebocardo
Thank you for the tip on Praxair, there is one located not even 20 miles from me!
Many tools are only rated for 90-110 psi, running them at a higher pressure I would not do. I made an adapter hose so I can measure the pressure at the tool end and adjust the compressor until I get 90 psi at the tool end.
I do not use 1/4" hose for anything except for filling tires.
RSA7.3
Aug 11, 2022 08:11 AM
FuzzFace2
Nov 3, 2019 09:26 AM
HRTKD
All Things Towing
19
Nov 5, 2016 10:50 PM
Rust Wrangler
1947 and Older Ford Trucks
Oct 1, 2016 01:37 PM
ThirdsACharm
Garage & Workshop
Jul 21, 2016 09:10 PM
