Replacing Parking Brake Cable
Old Feb 27, 2008 | 01:28 PM
badger2196's Avatar
badger2196
I have searched through the general Super Duty forums and found one question on this that went unanswered so I thought I'd post it here even though it's not specifically a PSD question. I applied the parking brake on the my truck this morning and the cable snapped at the pedal. The pedal is now firmly stuck in the down position and the brake warning light is permanently on.
My Haynes manual has nothing on replacing that cable for some reason - anyone here have any good info on how to replace that cable, any gotchas to watch out for etc. etc.
BTW, am I just being cynical or is the fact that this just happened shortly after having the CPS recall done at the stealership just a coincidence? My Brother was an auto mechanic for 15 years and would always tell me how sometimes they would introduce little problems when doing recall work so that they would get customer-paid follow-up work. Anyone else have mysterious minor issues after recall work?
Old Feb 27, 2008 | 01:33 PM
DCSpecial's Avatar
DCSpecial
If the cable snapped you should be able to easily lift the pedal by hand.
As for replacing it, it's pretty straight forward. Attach it to the pedal assembly, then (making sure the pedal is all the way up) attach it under the cab at the "coupler"
Old Feb 27, 2008 | 01:37 PM
badger2196's Avatar
badger2196
That's what I thought too but it seems to be stuck somehow, and I mean stuck!
Old Feb 27, 2008 | 01:43 PM
DCSpecial's Avatar
DCSpecial
So it won't budge when you pull on the release handle and try and lift the pedal?
When mine snapped right at the pedal all I had to do was pull the release and that thing would drop to the floor by itself...pull the release and easily lift it up.
Old Feb 27, 2008 | 02:56 PM
Dukernc's Avatar
Dukernc
Like DC said you should be able to just pull the release and easily lift it up on the pedal. By the way when mine snapped on my 99' (see my sig below) I had just gotten a recall the week before. Perfect timing! So, I had the dealer do it for free! Good luck!
Old Feb 27, 2008 | 03:01 PM
badger2196's Avatar
badger2196
Hmmmm, lift the pedal AND pull the release at the same time - now why didn't I think of that?
Releases just fine now.
Old Feb 27, 2008 | 07:25 PM
DCSpecial's Avatar
DCSpecial
Yep, the release locks the pedal assembly in place...and without the cable, there is nothing to automatically pull the pedal back up when you just pull the release.
Install is pretty easy.
If I remember correctly you'll need to push the pedal down to be able to view where the cable connects to the assembly. Then raise the pedal fully and connect it under the truck.
R202INT
15
Nov 30, 2020 09:00 PM
Robert_Mays
Oct 5, 2009 07:27 PM
slash31938
1978 - 1996 Big Bronco
Jun 10, 2006 08:38 AM
HoggIII
Feb 22, 2005 06:11 PM
rick
Mar 10, 2002 02:33 PM
