Tire Size
Old Feb 26, 2008 | 07:47 PM
Mike Norwood's Avatar
Mike Norwood
Tire Size
The truck is an '01 F-250 4X4 and the sticker on the door calls for 265/75/R16 and the truck currently has 285/75/R16. Are the 285's taller or wider? If they are taller, how far are they throwing the odometer off?
Old Feb 26, 2008 | 07:49 PM
jdecker88's Avatar
jdecker88
The 285s are taller then the 265s, I love how they give my 250 sits on the 285s but I am not sure how much they throw the odometer off.
Old Feb 26, 2008 | 08:07 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
A little of both, your 285s are an inch taller and an inch wider. 1-3mph difference...maybe.
Old Feb 26, 2008 | 08:12 PM
Mike Norwood
Many thanks. That is the information I was looking for. I am going to take the GPS out in the truck on a 10 mile run to figure the exact difference.
Old Feb 26, 2008 | 08:14 PM
NEWT92's Avatar
NEWT92
Use this link. http://www.miata.net/garage/tirecalc.html
Old Feb 26, 2008 | 08:31 PM
Mike Norwood
[QUOTE=NEWT92]Use this link. http://www.miata.net/garage/tirecalc.html[/QUOTE]
Geat tool there. Thanks.
Old Feb 26, 2008 | 08:44 PM
NEWT92's Avatar
NEWT92
Here is another one..http://www.csgnetwork.com/speedocalibcalc.html
Old Feb 26, 2008 | 10:49 PM
KelVarnson's Avatar
KelVarnson
The 265 is 31.65" in diameter.
The 285 is 32.83" in diameter.
Your speedo should read 3.73% lower.
I just recently went from 265/75 to 285/75 on my '02. My speedo went from reading high to reading exactly correct.
I just turned 100,000 miles indicated. Makes me wonder if I should have 3700 more miles on my engine warranty...
Old Feb 27, 2008 | 07:31 PM
ts_stroker's Avatar
ts_stroker
i am running 315/75/16 and my speedo is only off by 4-7 mph off depending on the speed i am traveling
Old Feb 27, 2008 | 07:48 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
Go here and use the info that others have posted.
http://www.ricksontruck.com/speedometer.html
Old Feb 27, 2008 | 07:49 PM
Texas Outlaw
Not a liberal...
Same deal as me.
sandman3510
Modular V10 (6.8l)
17
Jul 20, 2007 09:12 PM
exiled
Nov 10, 2006 09:07 PM
konan12
Mar 24, 2006 09:47 PM
MTman
13
Jun 10, 2005 07:22 AM
FXDXT
17
Mar 7, 2003 09:20 AM
