My mistake
Old Feb 26, 2008 | 03:50 PM
shoot4fun's Avatar
shoot4fun
I'll shut up now.
Old Feb 26, 2008 | 03:51 PM
sedly's Avatar
sedly
Have look at this pic.To me the way you described the 78 and later pump's,this look's like a later type.
Old Feb 26, 2008 | 05:51 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
That doesn't even look right, that tube has an extreme bend to it...not something Ford would do...the tube is twisted and kinked, and looks like it was "bent to fit" by a former owner.
The pre 1978 P/S pressure hose just screws on to the pump, there's no O-ring on the flared end of the tube.
The 1978 and later hoses have a short straight tube (no flare) with a small O-ring on it roughly 3/4's to one inch from the end of the tube.
The following info is Rated R.
The 1978 and later P/S pressure hose's male tube with its O-ring is inserted into the pumps female fitting...then it's tightened up.
Old Feb 27, 2008 | 12:25 PM
sedly's Avatar
sedly
That tube had me wondering about the bend in it as well.The bend is tight,it's almost kinked.I've ordered a new p/s pump,hopefully it comes in today.I have another one of these truck's,I looked at the p/s pump on it,and like you say NumberDummy,the hose is quite different.
Old Feb 27, 2008 | 12:32 PM
sedly's Avatar
sedly
I guess I should take the hose from the other truck.
Old Feb 27, 2008 | 03:31 PM
sedly's Avatar
sedly
Would the pump be completely wrong as well?
Old Feb 27, 2008 | 08:35 PM
flathead95hp's Avatar
flathead95hp
I don't think they make Type F fluid anymore, Isn't it now Mercon?
Old Feb 27, 2008 | 09:51 PM
sedly's Avatar
sedly
That's a good question,I'm not sure.
Old Feb 27, 2008 | 09:55 PM
flathead95hp
I can't remember the last time I saw type F, Mercon/Dexron is all in one now, at least thats what I use at work. Last ime I saw type F it was in a Steel can, and that ws in the early 80's.
Old Feb 27, 2008 | 09:57 PM
sedly's Avatar
sedly
Well I think I might have solved my problem.I will know tomorrow when I swap p/s pump's.
Unless the one I'm gonna put in is bad.
russellkr
Nov 2, 2002 11:18 AM
beartracks
Oct 18, 2002 02:20 PM
dale i
Sep 22, 2002 09:37 AM
rogwelch
Feb 12, 2000 11:29 PM
Jan 28, 2000 06:08 PM
