My mistake
Old Feb 26, 2008 | 03:11 PM
sedly's Avatar
sedly
My mistake
I think I have screwed up.The ram assist power steering,with the control valve,takes what type of fluid?
Old Feb 26, 2008 | 03:14 PM
masterbeavis's Avatar
masterbeavis
PS fluid will work.
Old Feb 26, 2008 | 03:15 PM
shoot4fun's Avatar
shoot4fun
Ram assist should be able to use standard p.s. fluid, A/T Fluid, even some lighter grader hydraulic fluids. It's only the rack and pinion types that are fairly easy to screw up, found on later models.
Old Feb 26, 2008 | 03:16 PM
shoot4fun's Avatar
shoot4fun
Gimme yer specifics, I can run them real quick and tell what you need.
Old Feb 26, 2008 | 03:19 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Type F ATF was used as P/S fluid from 1953 thru 1979.
According to the parts catalogs, the only use of Mercon prior to 1980, was on 1977/79 C6's. Every other A/T used type F thru 1979.
Old Feb 26, 2008 | 03:20 PM
sedly's Avatar
sedly
1976 F250 4x4
300 I6
stock power assist
Is this what you need?
Old Feb 26, 2008 | 03:22 PM
shoot4fun's Avatar
shoot4fun
NumberDummy got it. Yer good. P.S. fluid works fine.
Old Feb 26, 2008 | 03:23 PM
shoot4fun's Avatar
shoot4fun
Oops. Meant ATF works fine. Sorry. hard to screw them up, short of using water...
Old Feb 26, 2008 | 03:25 PM
sedly's Avatar
sedly
O.K,that is a bit of a relief.I got concerned,I did quite a bit of research on this forum.It came up alot,to use the atf type f.I was thinking that the power steering fluid is too thin.Maybe a new pump is in need.
Old Feb 26, 2008 | 03:28 PM
NumberDummy
FYI: You can edit your posts for up to one hour. Most ppl read thru the thread several times, and quickly learn to back up and read previous posts. Good thing too...I usually edit my posts several times once the brain gets into gear!
sedly's Avatar
sedly
Wait a sec,another post was made.I took took long typeing.
Old Feb 26, 2008 | 03:32 PM
sedly's Avatar
sedly
This is what I should be useing? Type F ATF.
Old Feb 26, 2008 | 03:33 PM
shoot4fun's Avatar
shoot4fun
you can use p.s. fluid, or ATF. Makes no difference. If it's making noise, try some additive made for power steering before replacing it. Don't want to ruffle feathers, so I won't mention my personal preference...
NumberDummy
Replacing the P/S pump? MAKE SURE you use a pump from 1977 or earlier.
The 1978 pumps have different fittings and use different P/S pressure hoses that have an "O" Ring on the male tube end. 1978 and later: You slip the pressure hose's male tube into the pumps fitting, then tighten up the nut.
1977 and earlier P/S pressure hoses will NOT work on 1978 and later pumps.
Old Feb 26, 2008 | 03:45 PM
shoot4fun's Avatar
shoot4fun
Yeah Sedly, Type F is fine.
NumberDummy, tell me how to edit my posts. I've never seen the "edit" button.
HAH! I seen it that time...! Duh!
