Rust Bullet® Rapid Fire Accelerator
Old Feb 26, 2008 | 07:41 AM
kjett's Avatar
kjett
Any out there ever use the RB accelerator? I need to paint the frame on my mud truck that I am building so I can get the body, motor and rest of the drivetrain in. The frame had been sitting outside uncoversed as a rolling chassis for the last 12 years (it was my uncles old 79 F-150 spare frame and axles). So needless to say the frame has alot of surface rust to the point that is is pitted. I have been hitting it with a wire wheel getting most of the scale off, and I'm ready to paint it. The problem is I don't have a place where I can paint it (or store it for that matter) inside. Being that its been in anywhere from the 30s to the 50s outside, can I even do it and make it cure properly? The accelerator is supposed to reduce cure times from 4 hours to 30 minutes, and was thinking this might be a good option.
Opinions???
Old Feb 26, 2008 | 02:59 PM
gnwalker's Avatar
gnwalker
I painted most of my frame with RB with temps in the 40s and it was dry to the touch within an hour. I cant say how long it took to cure but it seemed to dry much quicker than rustoleum would
Old Feb 26, 2008 | 06:56 PM
kjett's Avatar
kjett
Was that with just the RB or did you use the Accelerator mixed into it?
Old Feb 26, 2008 | 07:10 PM
Duke78's Avatar
Duke78
I wouldn't use the accelerator, it is an added component i believe. That means you got a half hour to paint everything... Rust bullet is too expensive to risk it. Prep it and paint it with the regular automotive fomula. Just my opinion.
Old Feb 26, 2008 | 07:25 PM
kjett's Avatar
kjett
Works for me! Thanks for the info.
PLCguy
Jan 19, 2017 07:53 PM
c2z4s9
17
Jan 8, 2015 08:43 AM
vortec 1
May 5, 2013 01:24 PM
fordman19762003
Paint & Bodywork
Apr 14, 2012 10:57 AM
rangermike
15
Mar 3, 2009 11:04 PM
