1978 - 1996 Big Bronco
Top
Old Feb 26, 2008 | 12:57 AM
Fordtrk26's Avatar
Fordtrk26
Top
There is a sqeaking that is driving me nuts. my top seems to be on secure but cant seem to be able to stop the noise. any suggestions.
Old Feb 26, 2008 | 01:04 AM
rollerstud98's Avatar
rollerstud98
may need new weather stripping between the top and the truck? our old bronco, i'm pretty sure it was the rear window that was squeaking, but we never fixed that
Old Feb 26, 2008 | 01:22 AM
Fordtrk26's Avatar
Fordtrk26
Sorry its a 96 do they have weather stripping for the top?
Old Feb 26, 2008 | 07:22 AM
bronk n blue's Avatar
bronk n blue
You didnt say if you take your top off or not. I do on mine, And when I put the hardware back on, I start from the front center and work my way down the sides to the back, being carefull not to over tighten. So if you check the weather stripping (good idea). Try reattaching in that order. Good luck!
Old Feb 27, 2008 | 01:44 PM
MBBFord's Avatar
MBBFord
Try taking the top off and possitioning it back on and retightening the bolts like bronk n blue said. IF that doesn't work, then take it off again and put some more weather stripping or foam and put it back on.
Old Feb 27, 2008 | 06:32 PM
blue beast's Avatar
blue beast
A bit of silicone spray will help the seals stay pliable and should be reapplied to all the
door, gate and top seals every 3 months or so. You could use armor all or another but
I prefer silicone since you can put the nozzle on and spray it into the tight spots!!
That TDL from pb blaster is good for assorted chassis squeaks including leaf springs,
Twist a screwdriver near the leaf ends and spray it in there. It has teflon in it and
is dry so it doesn't attract dirt But of course white lithium or even spray graphite would work. My fathers one ton van would squeak to high heaven if I didn't keep the
springs lubed, lithium would last 2 months or so depending on the weather, wd40 wouldn't last 500 miles, spray graphite lasted like 4 months but the TDL lasted like 8
months!! Don't forget to check the shock and sway bar ends they can make more
noise then you would think.
drake_bartel
15
Mar 27, 2021 01:29 PM
2017FSD
Nov 5, 2016 08:09 PM
squaredancer
Apr 26, 2016 06:16 PM
cbzdel
Feb 15, 2013 01:26 PM
DIRTY_D
Apr 15, 2008 12:35 PM
