keyless entry fob
Old Feb 25, 2008 | 09:44 PM
ldfry001's Avatar
ldfry001
keyless entry fob
is there anyway to tell if my truck has keyless entry. its a 1999 f250 xlt i thought that the keyless entry fob came standard on that truck, but wasnt sure. when i bought it the guy didnt give me a fob but i dont know if he just forgot to or what, but i just started thinking about it tonight.
Thanks
Lloyd
Old Feb 25, 2008 | 09:57 PM
Mike Norwood's Avatar
Mike Norwood
Welcome to FTE, Lloyd. In answer to your question, no not all the xlt's came with keyless entry, i know that mine did not.
Old Feb 25, 2008 | 10:01 PM
jeff7825's Avatar
jeff7825
To tell if you have keyless entry, turn the ignition switch from off to on 8 times in 20 seconds ending in the on postion. The locks should cycle if you have keyless entry.
Old Feb 25, 2008 | 10:07 PM
superduty4x4's Avatar
superduty4x4
Or, you can simply lock the doors- if you have keyless there is an indicator light that says "THEFT" that will illuminate when the doors are locked.
Old Feb 25, 2008 | 10:37 PM
rivrrunner's Avatar
rivrrunner
early 99 f350 CC 4X4 PSD now you got me confused: the locks cycle on the fifth key cycle but there is no theft light.
previous owner never had key fob...is there a check w/ a dealership and the vin # ??
Brian
Old Feb 26, 2008 | 12:14 AM
Mike Norwood
i don't believe the early 99 has the theft light like it doesn't have the cruise light, and yes the dealer can get you a key fob. if you have a salesman who happens to be a friend you can probably get the fob for nothing.
Old Feb 26, 2008 | 02:48 AM
Badluck's Avatar
Badluck
my early 99 doesnt have a theft light but it does have a cruise light and it cycles on the 9th lol
Old Feb 26, 2008 | 08:31 AM
superduty4x4
Well, I know my E-99 has the theft light but I've never checked to see if it turns on or not. My 95 with keyless would so I assumed this one would too.
Old Feb 26, 2008 | 08:41 AM
jeff7825's Avatar
jeff7825
I was wrong on my eariler post, the sequence is 8 times in 10 seconds, not 20. But anyhow if your locks cycle then you could pick up a remote on ebay for pretty cheap. That's what I did for my truck.
Old Feb 26, 2008 | 09:28 AM
cgl's Avatar
cgl
If your locks cycle... then... (copied directly from 1999MY Super Duty Manual)
Programming Transmitters
To reprogram all transmitters, place the key in the ignition and turn from OFF to ON (Run) eight times in a row (within 10 seconds). After doors lock/unlock, press any control on all transmitters (up to four). When completed, turn the ignition to OFF. All transmitters must be reprogrammed at the same time.
Good luck! Also, I believe the "THEFT" light on the dash is only on PATS equipped trucks, which yours is definitely not.
Old Feb 26, 2008 | 10:09 AM
superduty4x4
What the heck is PATS?
Old Feb 26, 2008 | 10:39 AM
rivrrunner's Avatar
rivrrunner
passive anti-theft system
Old Feb 26, 2008 | 12:51 PM
cgl's Avatar
cgl
Originally Posted by rivrrunner
Passive Anti-Theft System
Yup. Found in almost every other FORD vehicle except the Super Duty (pre-'08 anyways). PATS is FORD's "Chip-in-key" design.
Your ignition key will be quite a bit larger because of the electronics inside...
(This image was found on http://www.lvsales.com)
As opposed to the normal Super Duty key which is very slim and has a small plastic head.
Old Feb 26, 2008 | 12:55 PM
superduty4x4
Got it. So my 95, which did not have PATS, did have a factory anti-theft system. And it worked too I found out by mistake once. I would assume the SD would be similar maybe?
jfmaz
Dec 23, 2009 09:34 AM
95Ford4x4
Nov 6, 2009 05:18 PM
crownvic
Feb 19, 2008 08:08 PM
Pocketchange5
Aug 29, 2005 08:34 PM
oggjay
Sep 1, 2004 11:01 PM
