Sponsored by: Auxito
Injector Cleaner
Old Feb 28, 2008 | 11:28 AM
mikieday's Avatar
mikieday
i use seafoam in everything...however i have never run it thru my break booster...can someone explain or maybe show a pic of what to do
I would appreciate it
mike
Old Feb 28, 2008 | 12:26 PM
KingRanchMan02's Avatar
KingRanchMan02
mike
For this type of application, the brake booster vacuum hose is disconnected from the booster. Insert the vacuum line into the Seafoam can adn startr the engine. Let it idle. The vacuum of the engine will suck in the Seafoam and in some cases will cause the engine to stall. Do not apply any more than a half can this way. Put the other half in the gas tank. Do as slowr says,
Originally Posted by slowr w/o blowr
Just resist the temptation to step on the gas after you feed it thru the booster line. Smoke is awesome but you could suck up raw liquid and do damage. I Let my vehicles sit for 15 minutes after adding to intake and then idle for 10 minutes, then i drive it real easy untill it stops smoking.
Good luck!
Old Feb 28, 2008 | 12:50 PM
mikieday's Avatar
mikieday
thank you...i am assuming the booster hose is the only hose on the round base behind the brake fluid res...and it runs to the back of the motor????
mike
Old Feb 28, 2008 | 12:58 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
mike
Yup...thats the one. I use a small funnel and stick it in the end of the hose, and then slowly pour the Seafoam in. I put 3/4 of a can in and shut the engine off for 10 minutes. Start it up and wait for the smoke to clear, then pour in the rest of the can and shut it down again until I'm ready to drive it.
mrsvegan
52
Nov 2, 2013 10:33 AM
GBURKS
Nov 21, 2010 11:31 PM
zamunda
1997 - 2003 F150
16
Feb 3, 2010 09:21 PM
saubouin
2004 - 2008 F150
Dec 28, 2007 05:22 PM
hdman6
Feb 19, 2006 11:56 AM
