Custom Exhaust Help
Old Feb 27, 2008 | 09:46 PM
95F350XL's Avatar
95F350XL
Id make a flange like mine, and use 2 high flows, I gave you links for ones for like 30 something bucks. Of cut the flange off of the stock y pipe and then put the 2 cats on there. Either or.
Old Feb 27, 2008 | 10:45 PM
Redcoat's Avatar
Redcoat
what if i cut off the flange, and found an adapter to go from two 2.5 inch (are the stock pipes 2.5 inch?) down to one 2.5 inch pipe and just clamped this on and clamped on a 2.5in cat. would a parts store carry such an adapter
Old Feb 28, 2008 | 09:40 PM
reeds101's Avatar
reeds101
Redcoat, my exhaust follows a standard path out where the stock one went. You can buy new pipes at a NAPA (buying a pipe expander makes it easier once you are putting it together). And if your truck has rust underneath, save yourself a headache and buy new hangers too.
Old Feb 29, 2008 | 07:56 AM
95F350XL's Avatar
95F350XL
I used the universal heavy duty hangers, the stock pipes are 2.25 so you will need an adaptor for the 2.5 cats if you cut the flange off, or if you make the flange like mine then just use 2.5 pipes.
Old Mar 4, 2008 | 06:29 PM
66F100Again's Avatar
66F100Again
Do the aftermarket "universal" "high flow" catalytic converters hold up as well as the OEM-type? They seem quite a bit smaller; seems like they'd either overheat quicker under load...or not have the capacity to clean the exhaust as well as the original type?
1990F250Beater
Dec 15, 2016 04:30 PM
blue924.9
Oct 14, 2015 05:04 PM
NativeDescent
Apr 6, 2015 05:27 AM
Still Smoking
2004 - 2008 F150
23
Mar 5, 2013 02:07 PM
Midnite1987
41
Nov 10, 2012 07:56 PM
