window motor
Old Feb 25, 2008 | 12:12 PM
ss87's Avatar
ss87
window motor
hello,quick question.
my 92 250 passangers side window doesnt do anything. it doesnt go up or down. ive been looking around for instructions on how to replace the motor. is there anything that has a step by step for this. i have a f150 im stealing parts off of, i was thinking of taking its window motor. now, ive been looking at this and have read about drilling out the rivets. (excuse my ignorance) but is the motor hooked to the arm that moves the window? im assuming so but cannot figure out how to drop the motor, then replace the motor and hook it up to anything inside. looks like a huge pain, but id would like to fix it. thanks for any help.
Old Feb 26, 2008 | 05:21 AM
ccecilm2's Avatar
ccecilm2
It's easy. The motor is actually bolted to the regulator and the top portion of the motor's cast gear meshes with the stamped regulator gear. Once you remove the last bolt on the motor just pull the motor back a bit toward the outside of the door and it will drop down. A very good write up is in the link below, it's what I used when I replaced my motor.
https://www.ford-trucks.com/forums/1...e+window+motor
Good luck.
Edit: If you don't have thin wall socket for the motor bolts I suggest you drill a 3/4 hole at the "dimples". That will give you a little extra wiggle room for removing and installing. I didn't have a 3/4" hole saw so I used a Dremel with a cuting wheel and made 3/4" square cutouts.
Old Feb 26, 2008 | 06:38 AM
ccecilm2's Avatar
ccecilm2
Forgot to mention to check for proper operation before you put the door panel back on. My new motor was wired backwards (up button sent window down and down button sent window up) so I unpluged it and pushed a small screwdriver into the back of the motor's harness plug, pulled out the wires and reversed their locations in the plug.
Old Feb 26, 2008 | 07:04 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Is it the motor that's bad...or not?
Two other factors come into play.
1) Stripped plastic gear in the window motor (very common for this to occur). Replacement: D0AZ-62234A24-B .. Gear Kit, available from Ford ($31.60) and most parts stores.
When the plastic gear strips, the motor runs, but the window won't move.
2) The window roller has broken apart. Replacement: D6AZ-5323240-A. Available from Ford ($7.88) and every autoparts store.
The same roller was used from the early 1970's and up, on most cars and trucks.
The plastic roller has a flexible metal threaded stud that bolts to the end of the regulator arm (used with or without power windows). The actual roller portion fits into the window channel that's bolted to the door glass.
What happens: The metal stud is pressed into the plastic roller. It pulls out of the plastic roller portion, now the window either binds up, or falls into the door.
Old Mar 3, 2008 | 10:55 AM
ss87's Avatar
ss87
thanks for the help, it was indeed the motor.
got it replaced this weekend.
ss
mechelement
Aug 1, 2010 10:57 PM
Blue Rebel
Jun 12, 2009 02:14 PM
jasonpope
May 25, 2005 09:34 PM
calzone
Bronco II
May 23, 2004 01:21 PM
mrit
1978 - 1996 Big Bronco
Aug 11, 2003 06:56 PM
