Bronco II Ford Bronco II
power window motor help
Old May 23, 2004 | 07:35 AM
calzone's Avatar
calzone
ok. I need to change my driver's side power window motor.
I took off the door panel. The I tool off the plastic weather sheet. Now I am unsure what to do next. Is there anything else that comes off? Not much room to work with behind there. I understand that I am going to have to secure the window.
How to you get the power window motor out and replace it?
Old May 23, 2004 | 01:21 PM
Ken00's Avatar
Ken00
You have to remove the motor/regulator assembly, then remove the motor for regulator. I'm not sure if it's bolted or riveted, if it's riveted, drill them out and replace with bolts.
teamlx88
Feb 2, 2014 03:34 PM
cdasherm
Sep 8, 2010 12:27 PM
boggerted
Mar 18, 2010 02:32 PM
KiwiFord
Jan 27, 2010 12:12 AM
sparkyrhett
May 7, 2007 02:21 PM
