front main engine seal leaks bad
Old Feb 18, 2008 | 12:38 PM
mike L's Avatar
mike L
Do I have to remove the radiator to pull the h balancer off, how hard is it to remove the old front engine seal? Any other tips ?
Thanks
Mike
Old Feb 18, 2008 | 02:09 PM
ssidney's Avatar
ssidney
Thanks
Mike
no need to remove anything except balancer, you should be able to pop seal out with a large screw-driver (I assume your working on a sbf)
Old Feb 19, 2008 | 06:25 AM
mike L's Avatar
mike L
Can I use a steering wheel puller to get the HB off?
Old Feb 19, 2008 | 09:30 AM
ssidney's Avatar
ssidney
if it'll fit
Old Feb 19, 2008 | 10:47 AM
EPNCSU2006's Avatar
EPNCSU2006
You will want to use a puller that bolts to the center (metal) section of the balancer. Any kind of three jaw puller around the outside ring (rubber) has the ability to pull the ring off of the metal center, which you don't want to do. I've been able to borrow one from the AutoZone tool program in the past.
Old Feb 19, 2008 | 11:18 AM
ssidney's Avatar
ssidney
the steering wheel puller should be of that type (center bolt with pt and main body with 4 slotted holes, three of them in a triangular shape)
Old Feb 19, 2008 | 12:08 PM
andym's Avatar
andym
One thing I learned a long time ago is to use the right tool for the job. If you don't, you end up buying a lot of tools and parts that you broke because you didn't use them right.
Old Feb 19, 2008 | 12:36 PM
Archion's Avatar
Archion
Veteran: Marine Corps
Also when you get the balancer off, check it fir a groove, much like and axle seal, if the seal has cut a groove in the balancer, get a repair sleeve for it, should still be available at any decent parts store.
Old Feb 19, 2008 | 01:49 PM
ssidney's Avatar
ssidney
the particular puller described can be purchased for less than $20.00, so it's cheap insurance
Old Feb 19, 2008 | 01:52 PM
Josh88Ford's Avatar
Josh88Ford
you need a crows foot to pull it. You shouldnt need to pull anything else off except for the fan. comes out easy, but installing the new one was a pain
Old Feb 29, 2008 | 08:27 AM
mike L's Avatar
mike L
time frame for removing the HB
I called two Ford garages and they both said it takes 2 hours to do the job, is that correct?
Old Feb 29, 2008 | 10:41 AM
andym's Avatar
andym
That probably includes tearing down enough of the engine to get to the balancer. Once you have everything off, the balancer is about a 10 minute job with the right tools.
Old Mar 3, 2008 | 08:02 AM
mike L's Avatar
mike L
Someone above said you don't need to remove anything to get to the hb. I have a 5.0, looks like the fan would be in the way.
Old Mar 3, 2008 | 11:37 AM
andym's Avatar
andym
Then I don't know why it would take two hours.
Old Mar 3, 2008 | 12:13 PM
ssidney's Avatar
ssidney
1.5 hr beer break
