compression check
Old Feb 25, 2008 | 08:31 AM
darsacal101's Avatar
darsacal101
compression check
I did a compression check yesterday on my 1997 3.0 180000 miles and found 165-180 psi on all 6 good?? I am trying to determine if this thing is worth working on anymore. Thnx for all input in advance
Old Feb 25, 2008 | 08:50 AM
Pablo-UA's Avatar
Pablo-UA
what cylinders have 165? what 180....?
Difference is not so good. Was your engine warmed up well? Usually compression difference is not more then 5%, you have 10%.
Does your engine burn oil? What is your fuel milage?
Old Feb 25, 2008 | 09:37 AM
Rockledge's Avatar
Rockledge
Those numbers sound fine. Ford recommendeds that the lowest compression reading be within 75 percent of the highest reading. So if 180 psi is your high, then 165 psi is easily within limits (the minimum would be 135 psi.)
When you did the compression test did you make sure the throttle plate was wedged wide open?
Old Feb 25, 2008 | 10:26 AM
Pablo-UA's Avatar
Pablo-UA
I suggest, engine is good, does not burn oil, but I know 1 thing, when starter and ring gear are not new, compression test is not accurate.
Old Feb 25, 2008 | 05:44 PM
rubydist's Avatar
rubydist
I agree w/ Rockledge - those are perfectly fine compression numbers.
Old Feb 27, 2008 | 04:13 AM
darsacal101
engine was warm although it was beginning to cool off by the time I was done with cylinder 3. I went in this order 456123 .engine does not burn any oil but has a small leak,last time I figures gas mileage was running around 12 mpg but I am still trying to figure out my p0402 code. as to the throttle plate wide open I just had my wife hold the pedal to the floor while she cranked the engine
Old Feb 29, 2008 | 02:22 AM
Pablo-UA's Avatar
Pablo-UA
Exhaust Gas Recirculation Flow (EGR) Excessive Detected. Not sure about gasoline engines, but if this fault exists electronic diesel controll limits power.
daveengelson
Mar 12, 2017 01:04 AM
Chisum5013
Feb 4, 2016 01:14 AM
nickydobbs
Sep 17, 2014 11:58 PM
JHoffman93
22
Jul 25, 2014 10:50 PM
cowboy.2010
Feb 12, 2009 10:10 AM
