7 codes & Oil areation test failed...help?
Old Feb 26, 2008 | 06:40 AM
hunter101's Avatar
hunter101
Yes, all the clips were ok and UVC looked good. I ran it 2 days now and seems to be a little better. It hasn't died either recently. My main problem is it shifting into overdrive and jerking like crazy along with the "miss" and not having as much power.
Old Feb 26, 2008 | 07:39 AM
tjbeggs's Avatar
tjbeggs
Did you do anything with the HPOP leak? thats why I was thinking it still had air in the system that needs to be purged.
Old Feb 26, 2008 | 08:29 AM
clux's Avatar
clux
Originally Posted by hunter101
Almost forgot a few things I added as well. Added the Tru-Cool Max tranny cooler, installed the EB terminator, installed the OBA, and put on the 203 degree thermostat with the billet housing. So far, there are no leaks at all and it is ready to roll. only issues now is that the codes are there as well as the "miss" I am witnessing. The big problem I may have is when it shifts into overdrive while driving, it begins to shake and jerk irradically. Would this be my tranny going south?
Any ideas on all of these issues would be greatly appreciated??????
Another simple idea is check your fuel pressure. The shake and jerk thing sounds to me like you might not be pumping enough fuel for higher engine demands.
Old Feb 26, 2008 | 11:18 AM
MR5x5's Avatar
MR5x5
Wow. My guess is many of your codes predate your fixes, so you need a fresh view of what is going on since your fixes. Sounds like your tranny has gone south. Mechanical diode probably shot, tranny may well need to be replaced. To early to guess at the miss. You need a fresh code scan. Just a hunch, but the oil change was way overdue? Maybe as simple as dirty injectors? Double dose some DK for the fuel side. You'll find various vigorous opinons on adding detergents to the oil side. I'll leave that to you to research and decide.
Old Feb 27, 2008 | 01:48 AM
hunter101's Avatar
hunter101
Just a thought, would my TC have anything to do with the jerking when shifting into OD?
Old Feb 27, 2008 | 02:00 AM
gungho351's Avatar
gungho351
When I first started having tranny problems, that is what it did. Except mine did it going into lockup, it felt like the truck was going to jump when it finally reached lockup.
Old Feb 27, 2008 | 02:12 AM
hunter101's Avatar
hunter101
gungho351..... So was it your TC that ended up being bad or the tranny itself needed work?
Old Feb 27, 2008 | 02:19 AM
gungho351's Avatar
gungho351
Well it started out as a TC, but took the whole tranny out in the process. If you suspect that you have a TC problem, pull the inspection plate off the tranny. Have someone put it in gear and hold the brake. Roll under the truck and listen(or in your case just walk under it, lol thats a tall truck). I heard a loud tinging sound when I did this. You shouldn't hear anything just the motor. My guess is that when my TC went out it was from broken fins, that led to bearing failure, that led to tranny failure.
Old Feb 27, 2008 | 03:44 AM
hunter101's Avatar
hunter101
Did you put a standard TC in it or did you get an upgraded one? I think mine may be going bad as well, just don't want to throw too much money for a TC.
