4R55E tranny problem.
Old Feb 24, 2008 | 04:55 PM
jman_07's Avatar
jman_07
So my 01 Explorer XLT has the 4R55E i believe correct me if im wrong. But it really likes to hangup on shifts between 2nd and 3rd and now severly between 4th and O/D if u really step on it it just pauses at a certain RPM and wont rev and higher And then decides to slowly creep up to the point where it has to shift but Struggles alot. Also the other night between 4th and Overdrive It paused then reved up all the way to 6K rpm before it shifted??? EPC Solonoid valve body????
Help Needed
Thanks.
<!-- / message -->
Old Feb 24, 2008 | 05:06 PM
fordboy_52's Avatar
fordboy_52
this has been a huge problem with the 4r44e and 4r55e. read here:
https://www.ford-trucks.com/forums/5...lick-here.html
Matt
Old Feb 24, 2008 | 07:28 PM
jman_07's Avatar
jman_07
Wow sounds like a huge transmission flaw. What could be causing this do you think a rebuild is in the future or solonoid??? Im getting a flush and fill this week with a new filter and gasket.
Old Feb 24, 2008 | 08:04 PM
fordboy_52's Avatar
fordboy_52
if you have it apart, you just as well do the gasket. the fluid is the most expensive part of the whole deal. your too late to fix it with a flush
Old Feb 24, 2008 | 09:28 PM
jman_07's Avatar
jman_07
Yeah thats true Well what in these transmissions causes this??? Also i have had an antifreeze smell which i cannot find on this truck there is no leaks and its not loosing coolant But i can smell it strong. and i cannot find the source it seems to be strong on the right side around the radiator any ideas???
Old Feb 25, 2008 | 09:12 AM
jman_07's Avatar
jman_07
It could be a radiator cap im not sure ???
Old Feb 25, 2008 | 09:14 AM
fordboy_52's Avatar
fordboy_52
no idea, is your level going down?
Old Feb 25, 2008 | 02:25 PM
jman_07's Avatar
jman_07
Nope just a constant smell of coolant Not sure if its the cap or if its dripping out of the radiator there are no leaks at all.
Old Feb 25, 2008 | 03:06 PM
CMOS's Avatar
CMOS
A pin leak in the heater core could do this - smell but no visible loss of fluid.
CMOS
