Rocker arm
Old Feb 24, 2008 | 04:45 PM
edo379's Avatar
edo379
Rocker arm
Does anyone know the "offical" name of the rocker arm? I can't find one on the internet anywhere, and i've heard they break all the time so they cant be that hard to find!
Old Feb 24, 2008 | 05:18 PM
immastrokinnow's Avatar
immastrokinnow
its called a rocker arm and only heard of one or 2 breaking in my life. granted im 21 but still....
Old Feb 24, 2008 | 06:00 PM
Cuda_jim's Avatar
Cuda_jim
Yep, not many rocker arms break on ths 7.3, maybe you're thinking of the newer diesels. What engine you asking for?
Old Feb 24, 2008 | 07:09 PM
tjbeggs's Avatar
tjbeggs
they are called a rocker arm. They do break but I would not say all the time. See sets on ebay from time to time when others are parting out engines.
Old Feb 24, 2008 | 07:18 PM
MADVAN's Avatar
MADVAN
There was bad arms produced. They were in SD.
Somewhere i have stamping #s for the defective rockers.
Bill
Old Feb 24, 2008 | 07:20 PM
c00nhunterjoe's Avatar
c00nhunterjoe
you're more likely to bend a pushrod, but even that isnt likely
Old Feb 24, 2008 | 07:25 PM
edo379's Avatar
edo379
ha ha well i bent the push rod AND broke the rocker arm. does anyone know where i can pick these up and about how much they'll cost. do i have to go to ford or international?
Old Feb 24, 2008 | 07:29 PM
MADVAN's Avatar
MADVAN
Do you why did it happen? Over rev, ex brake, over boost ect.
This can/will happen if rod and rocker have been installed while the motor was not clocked.
Bill
Old Feb 24, 2008 | 11:09 PM
edo379's Avatar
edo379
Engine has 300,000 miles on it and happened when I was pulling a trailer up
a hill pretty good....
Old Feb 24, 2008 | 11:18 PM
immastrokinnow
post some pics when you get the old ones removed. and i would also do an oil change. anyone know if he should check the cam or not? lobe damage? just checking
Old Feb 25, 2008 | 12:32 AM
slowr w/o blowr's Avatar
slowr w/o blowr
I have had a few pushrods on t-444e's. I think the engine will compensate quite a bit and they are kinda hard to t-shoot. I dont know what causes it to happen. I allways wandered if my drivers were using ether to start their trucks and not wainting for the glow plugs to cool down. Then who knows how much that they are shooting into the intake.
Old Feb 25, 2008 | 08:09 AM
MADVAN's Avatar
MADVAN
It will happen again if you just replace the rod and rocker.
You have to find why now. A WAG now would be weak spring or sticky valve.
Was it intake or exhaust? Odds are ex.
Bill
Old Feb 25, 2008 | 08:41 AM
Action4478's Avatar
Action4478
My thoughts exactly ....
Old Feb 25, 2008 | 01:28 PM
edo379's Avatar
edo379
it was the exhaust side and the pushrod was hitting up against something making a knocking noise, what else could cause this?? would it just be loose? how do you check the spring or sticky valve? can i just push on it or anything?? would i have to take the whole head off if it needs a valve replacement? i would assume yes...
