Electrical Problems
Old Feb 24, 2008 | 04:23 PM
loneranger59's Avatar
loneranger59
Electrical Problems
Hey Guys! Just went outside to move my truck and cycled my glow plugs and went to start the truck and motor would turn over but didnt start. I turnned it off and went to try it again and still nothing. I pulled the key out but my dash panels lights were all on and the fuel pump was running yet, the doors locking and unlocking rapaidly? But the key was out I unhooked the batteries to get the truck to stop doing this and left them off for 5 mins and hooked back up. Same problems again?? I'm thinking its a computer but not sure. Im out of warrenty so any help would be appreciated!
Thanks,
Mike
Old Feb 24, 2008 | 06:46 PM
Maxium4x4's Avatar
Maxium4x4
What year? And have you ever had a water leak into the fuse panel?
Old Feb 24, 2008 | 06:56 PM
loneranger59
It is a 04 and there has never been water in the fuse panel that i know of. I disconnected the batterys and removed the pcm wire connections and the truck is still acting up. I traced it back to a relay under the hood beside the master cyl. I removed the relay and it wont do it and as soon as I plugged it back in it acts up. I cant find what the relay is for in my manuals.
Old Feb 24, 2008 | 06:57 PM
kevin22602's Avatar
kevin22602
I had issues like this last winter with a 00 powerstroke. Defroster/blower motor would continue to run after ket was removed and the speedometer quit working for a day. When the slush and snow went away, the pickup fixed itself. I still have not replaced anything, and everything has been working normal for the past year. I was told its a problem with the leaky windshield and dripping down on some circuit box. My windshield does leak a little, ever since new my filing cabinet gets wet up there on the dash. I don't know if this helps, but it may be a place to start!
Old Feb 24, 2008 | 07:52 PM
toolman05kr's Avatar
toolman05kr
I have to agree with maximum4x4, The windshield is leaking on the fuse panel, possibly a very slow leak. water gets in the panel and shorts out the circuit bars, causing all sorts of gremlins to pop up.
Old Feb 24, 2008 | 07:56 PM
Maxium4x4's Avatar
Maxium4x4
Toolman you look qualified....ASE Master Auto/Medium and HD truck Tech. Master Auto Electrician
Old Feb 24, 2008 | 08:02 PM
Maxium4x4's Avatar
Maxium4x4
You have to eliminate, so make a starting point. One place to look is for entry of water getting into the panel. Nothing you posted is common, but a point in the direction of a wire issue or water.
A no start can be a high pressure pump leak under normal symptoms. Until you find out what is going on electrically, I would disregard the high pressure leak for now.
Old Feb 24, 2008 | 08:14 PM
loneranger59
Just got done working on it again. My friend who is a mechanic just came over with his computer to see if he could tell anything. Nothing came up. I hooked everything back up normally but i pulled the relay out that kept click without the key in the ignition. There was a code that poped up saying it was the back pressure sensor. I have a feeling now that the problem is in the key switch wiring. Im calling ford tomorrow I cant go with out this truck for long this week. I let you guys know what it is anymore input will be greatly appreciated!
ford country boy
Apr 3, 2014 06:07 AM
cajun81
19
Jan 11, 2011 04:44 PM
F250 Munday
Oct 3, 2010 07:13 PM
nolanb
Aug 18, 2010 07:52 PM
hrhankypoo
Oct 1, 2009 04:08 PM
