Injector O-ring Failure Symptoms
Old Feb 24, 2008 | 02:20 PM
aocabrown's Avatar
aocabrown
Can someone tell me the basic symptoms of an injector/o-ring issue.
Old Feb 24, 2008 | 07:52 PM
7.3 Powerstroker's Avatar
7.3 Powerstroker
Well mine had failed and hydrolic locked the cylinder and bent and broke a push rod which in return ment i had to pull the motor and drop the pan to find the one piece of one of the pushrods.
Old Feb 24, 2008 | 08:39 PM
Tenn01PSD350's Avatar
Tenn01PSD350
A lot of smoke at startup, and perhaps as you drive. If it is fuel it will smoke gray/white. Also, mysterious loss of oil level on the stick with no visible leak, probably accompanied by blueish smoke. Truck still ain't right eh?
Old Feb 25, 2008 | 09:33 AM
aocabrown's Avatar
aocabrown
A little white smoke on cold morning but nothing else. Yeah...still ain't right. I replaced EPB sensor and tube and the IDM last week. I knew the IDM wasn't the fix but for a $150 IDM it will get the injector shop to shut up about that being the issue. The EBP sensor/tube needed a good cleaning/replacement anyway.
I'm going back to the shop this week to insist that I have an injector/o-ring issue with one of the four they put in. My problems didn't start that same day as replacement out of coincidence.
Old Feb 25, 2008 | 10:14 AM
Izzy351's Avatar
Izzy351
Also fuel/oil showing up in the coolant de-gas bottle. That's a classic symptom.
Old Feb 25, 2008 | 10:51 AM
FARM69's Avatar
FARM69
When mine went out the truck would literally smoke out parking lot every morning. It idled a little off, but once the engine got to operating temp there was no problems.
For some reason I couldn't go over 2500 rpms in gear. The engine would bog down and smoke bad again.
My fuel milage went crazy. I could get about 800 miles emptying both tanks. My oil level remained constant aswell as the coolant.
Nathan Cox
Jul 5, 2016 09:54 AM
Buck Dharma Fan
20
Mar 26, 2015 07:21 AM
built tough
May 22, 2012 11:22 PM
savage250
Oct 15, 2011 03:00 PM
73strokin
Nov 18, 2010 09:39 AM
