Any idea why I have more power when the truck is still warming up?
I've noticed this on other vehicles that I've driven over the years.
It is very pronounced on big iron gas engines at 1/4 throttle.
My theory is that the intake plenums are still cold enough to not give much heat to the intake air and it's entering the engine a lot cooler.
Cooler air is much more dense than hot air and the air mass in the cylinder is much higher resulting in a much stronger push on the piston during the power stroke of the 4 cycle engine. That's where the extra power is coming from.
According to one theory , the injector timing is advanced based on oil temp . ( i.e cold oil ,advance in timing ) oil reachs operating temps and it backs off the timing . There is a mod for putting a 4.1k resistor in series with the oil temp sensor just behind the hpop to trick it into thinking the oil is colder than it is . Is this just BS? The mod on this site near the bottom .
http://pages.prodigy.net/stevebaz/_i...az/index3.html
