Brake Lockup???
Old Feb 24, 2008 | 02:43 PM
2 stroke man's Avatar
2 stroke man
ya, i know. i was only using the lifts it up as a reference to the kind of weight i haul and why i need the brakes locked.
Old Feb 24, 2008 | 03:09 PM
nelstone74's Avatar
nelstone74
You want a low tech solution cut down an old broom handle so you can wedge in between the seat and the brake pedal. Instanly locking all the "working" breaks
Old Feb 24, 2008 | 05:40 PM
mudmaker's Avatar
mudmaker
Safest way is legs on the back of the trailer that swing down on the rear of the trailer. Another option is chalks. I had the same thing happen to me a couple of times. One time on a slope I put it in 4hi, kept it from rolling, but I didnt like watching my pickup buck like that. Cant be good on it, I now have legs that swing down.
Old Mar 16, 2008 | 08:59 PM
nitrogen's Avatar
nitrogen
just a thought.my brake controller warns of possible major electrical damage as a result of pulling breakaway while trailer is plugged in. its a prodigy
Old Mar 16, 2008 | 09:09 PM
mudmaker's Avatar
mudmaker
Could be, I have never pulled one with the plug hooked to the pickup. The only time I ever had the breakaway pulled it was done by a DOT officer. I just figured he pulled the plug on the pickup to make sure I running power to the breakaway thru the pickup.
Old Mar 16, 2008 | 11:16 PM
Ford_Six's Avatar
Ford_Six
I go for the most low-tech solution- chock the rear trailer axle. Two blocks of 4x4, one in front of each tire if it's a downward slope, one front and rear of one side if it's an upward slope.
Old Mar 20, 2008 | 09:53 AM
RexB's Avatar
RexB
Jack stands work under the rear of the trailer for my 12,000lb dozer. Cheap and easy. You prolly already have jackstands, just carry 'em with you when loading the big ones.
... i've got tractors so heavy that will even lift up the back of my truck (as in totally off the ground) if the terrain isnt right.
blue924.9
17
May 24, 2015 06:24 PM
kr95
Large Truck
Nov 14, 2013 12:08 PM
643NRK
All Things Towing
May 8, 2008 09:45 PM
ericsmith32
All Things Towing
Jun 30, 2005 04:47 AM
Fordhog
1947 and Older Ford Trucks
Oct 31, 2003 10:13 PM
