gear box replacement? other temporary options
Old Feb 23, 2008 | 05:52 PM
articphoto's Avatar
articphoto
I was told that i probably need a gearbox replacement. He said that on a shaft thing where there is a seal a grove commonly develops, and generates a leak. There used to be a repair kit, but unless you put it on super perfect, it wont last and you have to do it again.
The leak comes out on to the exhaust, and im halfway down on fluid.
Is just filling it an option till i can get a 'kit' or a rebuilt box, and what is the max time i should 'just fill it'?
Thanks a lot
1977 ranchero gt 400
Old Feb 27, 2008 | 02:45 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Thanks a lot
The same power steering gearbox was used from the mid 1960's thru the 1990's. The two seal kits are available from Ford (F3AZ-3E502-A input shaft kit, & D7AZ-3E501-A sector shaft kit) and parts stores.
Rebuilt gearboxes are available from NAPA. but the the rebuilts usually don't last past a year or so. A company called Red Hat rebuilds the boxes properly and adds a bearing that Ford left out (prolly on purpose).
Old Feb 27, 2008 | 02:50 AM
articphoto's Avatar
articphoto
i only know of red hat linux, and google dosent mention any red hat automotive
Old Feb 27, 2008 | 03:44 AM
NumberDummy
it's red something...someone posted info on the company two days ago.
I'll look for the ref...
EDIT: Found...see next post.
Old Feb 27, 2008 | 04:10 AM
NumberDummy
redheadsteeringgears.com
rmarquet
Feb 29, 2016 04:31 PM
xpanmanx
Jun 16, 2013 10:46 PM
AbandonedBronco
1978 - 1996 Big Bronco
Feb 8, 2010 12:33 PM
dogranger
1983 - 2012 Ranger & B-Series
Jan 30, 2009 04:39 PM
daggerNC
Jun 15, 2007 02:18 PM
