Three Cooling System Questions
Old Jun 16, 2013 | 12:56 PM
xpanmanx's Avatar
xpanmanx
  1. Is there a way to pressurize my Expy's cooling system without running the engine, so that it's cool to the touch and I might hear a hiss from the pinhole or crack?
  2. Are there any tricks to replacing the thermostat or water pump? It seems pretty straight-forward to me.
  3. How do I flush/fill/bleed the cooling system properly?
My truck is a 2000 Expy 4.6L XLT 4x4 6-code with 175k+ on the clock. It's got dual air.
In the next week, I need to find a radiator leak, then replace the factory-original thermostat and water pump and finally flush/fill the cooling system.
I think the leak is in the upper-passenger corner of the radiator. The coolant residue on the surrounding areas is convincing. But I can't eyeball the leak, which explains my first question
Question #3 is born of ignorance. It was probably 1983 when I last installed a Prestone Flush/Fill kit and that car had a good ol' pressure cap right in the middle of the upper radiator tank. But my head fills with questions when I contemplate the overflow bottle on my Expy.
THANK YOU
Old Jun 16, 2013 | 01:05 PM
alloro's Avatar
alloro
You need a radiator testing kit to pressurize the cooling system. Perhaps your local auto parts store rents it.
Old Jun 16, 2013 | 08:56 PM
xpanmanx's Avatar
xpanmanx
I was thinking of building my own pressure tester by pulling a rubber tire valve stem through hole drilled in the middle of a gutted de-gas tank cap. Do you think this would work?
Old Jun 16, 2013 | 10:46 PM
alloro's Avatar
alloro
Yes you can make a pump like that. What it will lack is a pressure gauge. You don't want to go over 18 PSI when pressurizing the system.
86ford302help
1983 - 2012 Ranger & B-Series
May 31, 2015 11:28 PM
davidkstyler
Jan 14, 2011 04:55 PM
f150XLTLariat
May 12, 2007 01:05 AM
butchhutch
Aerostar
Aug 12, 2006 07:51 PM
ConnertuckyF150
May 14, 2005 11:14 AM
