2wd c-6
Old Feb 23, 2008 | 04:58 PM
Glenn Graham's Avatar
Glenn Graham
2wd c-6
is it possible to use a 2wd c6 on a 4x4 by just removing the tailshaft or is there more to it than that?
Old Feb 23, 2008 | 06:39 PM
RNOVRIT's Avatar
RNOVRIT
More to it than that....
You will have to change the out-put shaft also.
Old Feb 23, 2008 | 06:40 PM
cykoticford's Avatar
cykoticford
you need a shorter out put shaft not hard to swap out if you good at rebuilding transmissions. it just takes time its one of the first pieces you put in so the trans has to come all the way apart
elkarcher1716
13
Mar 20, 2013 10:06 AM
gt40racing
Mar 28, 2010 01:13 PM
79f100six
Sep 3, 2007 08:57 AM
supercab4x4dually
Jan 12, 2004 01:40 PM
jtiggerh
1978 - 1996 Big Bronco
Feb 14, 2002 12:14 PM
