E-Brake?
Old Feb 23, 2008 | 11:41 AM
sedly's Avatar
sedly
E-Brake?
I am missing the return spring on my '76 F250 4x4.I have searched the forum on this,but couldn't find out if I actually need it.Do I? I think I do.
Old Feb 23, 2008 | 12:46 PM
sedly's Avatar
sedly
No comment's?Well I think I need the return spring,so I guess I will try to find one before Monday.
Old Feb 23, 2008 | 12:56 PM
OldMetal's Avatar
OldMetal
Does the pedal return all the way up?
You could always find any old spring the right size to make it work.
I keep any spring I can fine for these type of things.
Old Feb 23, 2008 | 01:03 PM
sedly's Avatar
sedly
No it doesn't.When I release the brake,the cables go slack and just hang there.The shoes don't release from the drums either.
Old Feb 23, 2008 | 01:17 PM
OldMetal's Avatar
OldMetal
The cable may be froze up, this happens a lot in snow country.
Get under the truck and pull on the cables with your hand, you should be able to pull them one at a time and feel them come out and return easily, if not you need new cables.
Old Feb 23, 2008 | 01:19 PM
sedly's Avatar
sedly
I managed to free them up with very little effort.Is the return spring only for the foot pedal?If it is, then I'm not too concerned about getting one right away.
Old Feb 23, 2008 | 01:24 PM
OldMetal's Avatar
OldMetal
As long as the cables work freely you should be ok, I need to pull my pedal up as well when I use it but I need to change my cables out so I don't use it, one of my cables is broke.
Old Feb 23, 2008 | 01:29 PM
sedly's Avatar
sedly
The spring's on the cable,(the end that attaches at the brakes),are what should make the brakes release?
Old Feb 23, 2008 | 01:35 PM
OldMetal's Avatar
OldMetal
Thats correct and they have no effect on the pedal.
Old Feb 23, 2008 | 01:43 PM
sedly's Avatar
sedly
O.K.,thank's that solves my issue.I will need to lube the cables up better,or maybe I have to switch the left to the right.But that's good new's at any rate.
pcarring
Offroad & 4x4
18
Jun 11, 2014 12:20 PM
x1hunter89
Dec 4, 2006 04:43 PM
THEBOOGIEMAN
Offroad & 4x4
36
Mar 29, 2006 09:37 PM
hunter1988
Appearance & Dress-Up
17
Feb 16, 2006 06:01 PM
69BRONCO
1966 - 1977 Early Broncos
Mar 14, 2002 01:45 PM
